C3 1975 M400 Auto Transmission fluid help/guidance needed
In the process of replacing the pan gasket and filter. Any recommendations for the type of fluid one should use. The car has a 350 engine with the M400 auto transmission.
Welcome to the forum! Try asking here.
https://www.corvetteforum.com/forums...performance-3/
Received 19,289 Likes
'20-'21-'22-'23-'24
Moved to C3 Tech/Performance.
read this article, it appears type F for Ford is the best for transmissions prior to 2000 due to lowered viscosity of newer fluids for gas mileage purposes.
http://www.hotrod.com/articles/choos...rformance-car/
