Dieseling at shut off
I have a big block 427 motor on a 66' corvette and I can't seem to get the dieseling to stop after turning off ignition. This forum has been very helpful with some suggestions but I am now desperate for a more definitive solution. I have spend so much time in the garage trying to correct this issue.
So much appreciated,
David
David
Just another Corvette guy
Idle too high or timing too far advanced?
ddtully (03-30-2018)
Greg is right on.
If I start my 68 427 briefly with out allowing it to warm up it will run on at shut off.
A properly warmed 427 and properly timed should not run on.
A 4speed car should have a warmed idle of 750 rpms and initial timing should be 16-18*
Marshal
Marshal
David
David
No one will like this, but my 425 has the factory timing and idle speed.
It will diesel every time I skimp on octane. I can get it to stop when using 91 octane and retarding the timing, but loose mega HP.
Dom
Dom
The throttle plates are open too far. Do whatever you have to too close them up a bit.
just the way it was and ran back then with all the same parts that GM built them with.
It did it with the stock Holley also. I adapted a Q-jet to it and upped the power and fuel economy, but it still wants good gas.
I did get some advice here on the forum about changing the vac can and distributor springs, and that might be what I need to close them a bit.
Dom
I am going to check this today
I don't disagree that timing could be too advanced leading to detonation leading to hot spots in the combustion chamber, however I would suspect too low of initial timing first.
When the initial timing is set too low it leads to very hot exhaust and combustion chamber and forces you to open the throttle blades farther to get it to idle making dieseling more likely. Too much heat in the combustion chamber and a throttle opening seems to be the cause for run-on or dieseling from what I'm seeing with guys here.
If there is a lot of carbon built up in the combustion chamber this can be a contributing factor as well. Do you plugs look pretty sooty or black when you pull them? If so then the chamber is likely in a similar condition if it has run for any length of time like that.
Water poured slowly into the carb while holding the RPM up to maybe 3000 or so on a fully warmed up engine can clean carbon out.
I can't get mine to run-on even if I hold the throttle at 2500 RPM and turn the key off. But I'm running aluminum heads (less heat in chamber) and have the timing set to 19* BTDC for the cam I'm running which allows me to close the throttle blades for idle.
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,922 Likes
