Lots of play in Steering Wheel
before I replace the whole column does anyone have any suggestions?
Last edited by patrick1974; 03-15-2018 at 04:07 PM. Reason: adding video of the problem
thanks, if it is one of those two would you suggest then just replacing the column? I am at the point where every little thing is adding up and I found completely new T/T columns for under $800 - I just dont know how difficult that would be to replace
The steering box is not part of the column, it just attaches to the end via the rag joint. Btw, you also need to check if the rag joint is torn, very common problem and gives tons of play when it's bad. Have someone move the steering wheel back and forth (with engine turned off) and look at the end of the column (in engine compartment), rag joint, and steering box input shaft. The input shaft to the box should move exactly as the steering wheel does.
The column is pretty easy to replace, btw.
patrick1974 (03-13-2018)
St. Jude Donor '22
if i read it right?
it is not a steering wheel that moves side to side but
turning doesn't get to the steering box
as it should?
2 different problems.
get a helper and see what is going on.
as it should?
the problem was the rag joint, I just checked it - I am not a mechanic so this has been a very interesting experience - time to see how difficult it is to replace.
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Willcox
The following 2 users liked this post by Willcox Corvette:
patrick1974 (03-15-2018),
Rescue Rogers (03-14-2018)
Dementer sole survivor
Received 6,287 Likes
2016 C3 of Year Finalist
After you fix the rag joint check the steering box, you maybe able to tighten up the bearings without anything more than labor. it will help if there is still slop
addendum, its not just the rag joint - there is something seriously wrong with how loose the wheel seems I made a video of it, but I am not sure I can post it here in the forum
Put it on youtube. Then when you click "advanced" editing there's a youtube button that takes your youtube link and makes an embedded video of it.
Emerging Vendor
If the four 12 point tilt knuckle bolts are tight, next is the plastic sphere at the joint between the upper and lower shaft, and last would be the upper and lower lock housing bearings.
Greg
Looks like the very top end of the column tube has broken loose/apart. That is the non-moving part of the column that the tilt mechanism bolts into.
I had that happen years ago with similar symptoms. Column has to be completely disassembled and then welded to repair. Or since you said you could get another column that's an option as well.
It's easy.
Remove the panel under the column
Remove the air duct (takes a little wrestling)
Remove 2 bolts holding column up + 2 nuts on firewall. Columns tilts down.
Disconnect electrical connectors (one for horn/turn signals, one on ignition switch)
Disconnect rag joint
Pull column out of car.
Might be missing a small thing here and there, but that's about it. Nothing to be scared of.
