2005 C6 Corvette LS2 ENGINE 24x for 05 Corvette or LS Conversion - $5,000.
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Swap out your LS1 for an LS2!
FOR SALE: Used 2005 C6 Corvette Engine/Motor 24x - Motor has about 60k Miles
243 Cyl heads fully rebuilt with new seals, valve job, and slight mill to clean deck
surface & new Fel Pro BLUE valve stem seals - Cometic Gaskets and
ARP HEAD BOLTS. New timing chain and Damper - Oil pump
modified for higher pressure. All new gaskets and seals.
Engine comes with intake manifold, LS2 injectors & coils wires and plugs.
IT's fitted with a 4th GEN CAMARO oil pan and pickup tube and what
I believe are G8 exhaust manifolds to make swaps easier. fitted
with used waterpump and balancer. Includes LS2 injector covers as well.
The throttle body installed is NOT WORKING and only installed to keep
the intake clean.
Please PM me questions or call Corvettes of Westchester at
914-332-0049
$5,000. outright - Install and tuning possible here in the shop.
These photos were taken before the engine was completely assembled.
Thank you - Chuck CoW
the intake clean.
914-332-0049
