79 Tank Removal Overview, Tips & Tricks
I've read a few of the tank removal threads on here, but I haven't come across any good high-level overview of the major steps, nor pictures for a later gas tank.
I've removed all the spare tire junk, siphoned all the gas out that I could, let the car run for 2 hours to try to get as much possible out of the tank and lines (2 hours didn't do it...!?!?), disconnected the battery, & removed the exhaust from the muffler hangers so they hang down a bit to make more room.
I struggled to remove the removable cross-member (lost a socket inside the frame rail for a while, then had to cut a bolt in half that was messede up- sparks and gas tanks are a scary combo) but it's fully loose now.
Specific questions:
Yes, I have the AIM, but the quality of the drawings is pretty terrible.
Thanks.
Adam
Specific questions:
- Where are the bolts for the straps?
- Do you have to remove one or more mufflers? (I've already removed them out of the hanger brackets so they're hanging down lower than normal)
- Hose connections- where do which ones come off? -I can cut any fuel lines because I'm replacing them with Earls VaporGuard EFI hose, but I don't want to cut the line to the charcoal canister.
- Electrical wires- where?
Thanks.
Adam
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
We use a transmission jack to remove the tanks while on a lift. If you remove the fuel door, bezel and the boot, and slightly drop the tank you'll get to the hoses below easier. While if you remove all the items above you can still reach the hoses without dropping the tank, it's just easier if you drop it about 2" then you can reach them easier.
The strap bolts nuts are located in the rear crossmember... if you have the AIM... go to page 390 it shows a great view of where to access them at. Section 8A page 1 shows you a very clear view.
Once you remove the cross member and the strap nuts, you should be able to drop the tank without any issue.
Willcox
Willcox
The following 3 users liked this post by Willcox Corvette:
Pretty sure you will have to drop the mufflers all the way down. I had to on my 79. I have the tank out now replacing the sock filter.
NewbVetteGuy (03-27-2018)
Definitely drop the exhaust. It clears up a lot of area. After pulling the the two hangars at the back it's only 6 bolts, 2 at the cross member and 4 at the cat (or pipe as the case may be).
Willcox
Willcox
I did not know that I had to remove the fuel door and boot first, I'll do things in that order.
I'm honestly a bit frustrated by the AIM; it wouldn't be that much more difficult to list things like bolt measurements, nor the order of dissassembly / reassembly in the diagrams. They're just diagrams and nothing more; glad I got one fairly inexpensively as had I paid full price I'd definitely feel ripped off.
Adam
Adam
(I'll cut the two on the passenger's side as I'm pulling them out and I'll be more careful with the driver's side, then.)
Adam
Yes. You are correct about the lines. But the 2 that run together are on the passenger side.
Former Vendor
Thanks as always, Willcox! I checked the AIM and saw the cross member bolts for the straps; I did NOT expect them to be there, honestly a pretty slick way to do it.
Adam
Adam
While the AIM will show you good pictures, it won't tell you step by step on how to do a job. The factory service manual and supplement will go a long way when combining it with the AIM. For us, we have an unfair advantage, we've done this job over the years multiple times and know the short cuts.
Willcox
You have to remember, the book is laid out in the order the car was assembled... They are just diagrams but keep in mind these were the pages the line workers used (every day) to assemble the car.
Willcox
Willcox
Adam
Some folks on here push buying the AIM as if it were a service manual and the first thing a new Corvette owner should buy; some questions simply get answered with "bought an AIM yet? -If not get off the internet and go buy one!" (then you go and buy one and say "jeeze, that's a crappy, old, not-very-useful diagram. Now I need to go back to CF and find some who understands what an internet discussion forum is for and start all over again...".
Adam
Adam
I was able to remove the mufflers from the hangers and then loosen the connectors @ the diff -I didn't have to take the headers off of the heads nor disconnect the exhaust from the headers.
At first the tank wouldn't fit down between the mufflers but I jacked my jack up as high as it would go and that enabled me to stand the tank up on its skinny end and pull it out underneath the car with the exhaust still partially attached.
-My strap bolts were totally and complete rusted out- the driver's side froze up completely but I didn't quite realize it and I spun the entire strap around about 5 or 6 times and then the thing snapped in two... (I sprayed penetrating oil on it before but I probably should've zapped the thread with a wire brush first...)
The straps seem to be old sold in pairs and mine was missing the rubber anti-squeak pads (tank was dropped back in 2016 to get rid of 12-year-old gas by someone else who apparently never replaced the anti-squeak pads) so I'm going to have to buy a new pair, but they're surprisingly cheap. -Other than that pretty uneventful.
I got all the hardware wire brushed and the top half of the tank wire brushed. Hardware including the removable cross member has all been anti-rust painted and just needs a top-coat.
My Eastwood tank paint gets here on Wednesday and I'm trying to have the tank fully prepped ready by then.
I have a LOT of rust removal to do but there's nothing but great metal underneath so far. -I'll take some pictures around inside the cavity where the fuel tank used to be. Maybe I'll do a iPhone panoramic and post it on FB and link it here so you can really pan around and look at whatever you want in there.
I cut the rubber lines connecting to the fuel out and fuel in as I'm replacing them all; I didn't cut the line coming from the charcoal canister, but I should have as the rubber is just super, super deteriorated and will need to be replaced.
Adam
After siphoning out all the gas, I let the engine run until it died- trying to pull as much fuel out of the tank and lines.
-I also found out why my fuel gauge stopped working a couple months back- the little push-on wire connector that connects to the fuel sender had popped off and was just hanging there. The rubber "boot" around the fuel door was filled with super nasty stuff and I cleaned it out and it seems I got over zealous and popped the thing off. In retrospect that WAS about the time that the fuel gauge stopped working... *Forehead SMACK*!
Tip #1: When removing the gas tank cross-member have one of those magnets-on-a-pole ready. If you're anything like me you'll drop either the bolt or a socket into the frame rail just out of reach.
Tip #2: My Gymkhana steel leaf spring jacks the rear end up high enough that my jack fully extended won't quite reach the bottom of the fuel tank; have some boards at-the-ready.
Adam
Adam
jacks! you don't need no stinkin' jacks!
Adam
Adam
Updated photos:
I used a wire brush attachment on my 18v drill to wire brush the whole tank- for the small, rusty area around the lip where the two halves are welded together I used a dremel stainless brush attachment.
I rocked the tank back and forth upside down to get most of the last bit of gas out and uses a few paper towels to get the last bit of liquid out and dirt and rust bits in the bottom of the tank.
Then I cleaned the whole tank to prep it for paint with oil / wax remover and then with rubbing alcohol.
Taped off the top of the tank as shown in the photo below and applied 2-3 coats of the Eastwood Tank Tone paint. It has SUPER intense fumes but it dries shockingly fast. I think it looks great. It took 1 1/2 cans to paint the whole tank; some reviews online said 2-3 cans so I now have another 1 1/2 cans extra if anyone wants some.
The last photos show the completed tank with the 1982-style fuel pump hanger just fit into the hole. I'll have to get the hanger height and bracket figured out for my Walbro EFI pump and Holley Hydramat and post those pictures, too.
My new straps and anti-squeak pads aren't due here until NEXT week, but I have a lot of rust remediation and fuel line work to do, to keep me busy for a while...
Adam
Adam
