Cork gaskets don't fit finned alu. v. covers
Hi everyone
I bought a pair of fel-pro 'blue stripe' VS12869 gaskets yesterday, but it seems that they don’t fit so good. One side fits good but the other side doesn’t.
A second problem is the ‘double holes’ on one side of the gaskets. One hole lines up good with the cover. But then there is a second hole that is of no use to me, and makes it impossible to fit the gaskets flat against the cover.
What is the best way to trim the cork gasket so I don’t ruin them.
See pictures below:
See pictures below:
Received 2,125 Likes
You must be too young to know what the extra hole is for. I find it ironic that gasket companies still make that extra hole gasket for an engine that hasn't been around in decades; the 265. Anyway, those are great gaskets and seal really well. I too had a set that seemed a little oversized but perhaps the valvecover itself is the issue.
If you want to trim one of them, an exacto knife or razor blade will work.
I have had 99% success using Permatex Gray on the valvecover side only. That way I can easily remove the cover for checking valvelash, etc. If applied liberally to the cover, then center the gasket, then flip it right side up, put some weight on it overnite. If you put bolts thru the holes as it dries they will line up perfectly later.
Does it matter on which side the blue silicone/rubber lines go? Towards the valve cover, or the heads?
Got me there. Never gave it any thought. I would believe the blue stripe means something ONLY to the manufacturer and marketing lingo.
I believe its meaningless for actual sealing because oil is on both sides of the gasket. Its not like some gaskets that are "labeled" or clearly marked:, one side air-one is for side gasoline or this side up, or this side towards block, etc.
You have chose wisely on your valvecovers. They have four things going for them that cheap ones do not.
Stronger "Cast" aluminum instead of stamped.
Rails to hold the gasket in place.
Rockerarm "drippers"
And a closed off baffled / oil fill port.
I think my valve covers are good. It are the aluminum finned ones with the crossed flags logo. I think it was originaly from an LT1.
Is this thea sealant used between the valve cover and the gasket?
https://www.permatex.com/products/ga...asket-maker-2/
I've heared 'the right stuff' by Permatex is also good...? Or are all these products just the same?
No, there're not all the same. Each color has a specific purpose. They even make one for waterpump / thermo housing. Its glycol proof.
But YES! on the link to the gray stuff, exactly. I have had really good luck with that on valvecovers, but use The Right Stuff elsewhere. And yes that's basically the famous Permatex Black. But in aerosol instead of a squeeze tube.
If you think you will never need to check the valvetrain or valvelash, by all means coat both sides of the gasket. Otherwise just "glue" the cover side.
Re-snug your bolts after a couple days then again later. You should be leak-free..
