Confusing Wiring Problem Persists - Turn Signals
Complete engine bay wiring (forward lamp and engine harness) and installed new led lights in dash and rear lights and side markers. Installed new led flashers with grounds. Insured all grounds were in correctly and tight. Installed new Turn signal switch. 4 ways work perfect. Brake lights work perfect and back up lights and tail lights.
Problem - no front side marker lights. With led bulbs installed they are very dime and don't flash anywhere. Normal bulbs don't light up at all. With normal lights installed and led rear lights my signal lights on the dash come on with the head lights. They don't with the led bulbs installed.
I'm so confused,help please!
I know that LED lamps are all the rage but they cause obnoxious problems in circuits that weren't designed for them.
Have you cleaned/inspected the rear lamp harness ground near the radio antenna?
When you say marker lights do they work with the park lights on? I may be wrong but they do not flash. Do the rear and front turn signals work? Just cause the 4 ways work that is a different flasher than the turn signal flasher. Do you have the correct turn signal flasher for your configuration? When the dash indicators light steady the circuit thinks there is a burnt bulb somewhere? Ensure all your grounds are good and your wiring to the front is correct. Use of a meter to take voltage reading at the flasher with the front wires disconnected would help. You could have a front wire to ground loading circuit down.
You either have to;
- add a load resistor to each front signal light and the running light circuit.
- add relays to isolate the marker light from the signal light.
- wire the marker lights to be grounded so they only come on with the running lights and don't flash with the signals.
- wire the marker lights to be grounded so they only come on with the signals but don't come on with the running lights.
- keep using normal bulbs in the front of the car, maybe rear too.
I'm not a fan of resistors, they tend to get hot and fail at the connections, melt things or burn out a lot, especially if they are connected to power all the time. But, they would fix this. I wouldn't go for 30W resistors. Try a 10W body size running maybe 3W or so. Somewhere around 50-65 ohms.
Relays would work and not burn-out or melt anything, but I can't picture a circuit that would work and give the same functionality without using 2 relays.
The other options, well they fix it but are probably not what you want.
You either have to;
I too dislike the use of power (>5W) resistors outside of enclosures designed to contain any damage caused by the heat they generate in both normal and problem (like over voltage) situations.
