Mechanical Oil Pressure Hose
I'm struggling with a simple problem; can you folks help me identify the location where the mechanical oil line runs through the firewall on a 1972 corvette? I'm replacing mine but the old one was removed before the engine went back in and I can't find the grommet the hose went through. A picture would be great if it is visible in the engine bay.
Received 2,878 Likes
Thank you so very much
Thanks, where did you purchase this? Will it fit the small block? Where did you go through the firewall for the gromet?
The following 2 users liked this post by theandies:
CA-Legal-Vette (04-22-2018),
sug (04-22-2018)
Thanks, I will order it, do you remember where you plumbed it through the firewall? it looks like it has its own rubber grommet, probably because of the diameter. Real estate under the dash is tight and any good advice is much appreciated.
