Vacuum line mix up?
2018 C3 of Year Finalist
Vacuum line mix up?
My 69 wiper motor has the small auxiliary pump on
The driver side of the pump. Were does the line for
The headlight washers go? On the end or underneath?
And the windshield washer line. I think I have them mixed up.
Thanks for your help.
I was afraid you were going to say that. That’s how mine are .
My problem is they the washers come on with the wiper switch.
As long as the wipers are on the washers stay on. Maybe someone will have an idea. Thanks for showing me that .
Is it possible that you installed the wiper switch upside-down? It IS possible for it to be installed in that manner. (Or the connector could be installed in reverse fashion.)
JBrooke825 (05-22-2018)
So it could be a problem with the wiper motor release mechanism, the coil operating the "hook" or with the wiper switch (not opening the circuit after pushing the button, so the coil will be engaged all the time, but this would burn the coil after some time).
There is very good documentation regarding the wiper motor (mechanical and electrical) from Willcox on his web site and here in the forum.
That’s sort of what happened before. The resistor in the old pump
Was burnt up . I finally bought a new pump from Willcox. Seems to do the same thing. New switch ,from them also. All new harness,new vacuum
Lines too. I keep filling up the bag under the fender. Ac. I hate to just give up and unhook them but I might have to. Everything else works fine. Thanks Jim
