Need help! Where does this vacuum line go to?
Like title says, in the process of putting the 69 back together and do not recall what it goes to. Any help or picture's would be much appreciated.
On my '72 roadster, that line goes over and above the heater box and connects to a "T" of a much larger vacuum line. Can't supply more info, as the car is currently under cover until the weather breaks a little more.
Duane
Duane
Received 2,878 Likes
Hi l,
As Duane said that small vacuum hose is connected in a T in the vacuum supply hose for the wiper door actuator. It supplies the vacuum that operates the heater and defroster controls.
Look for a T with 2 large nipples and 1 small nipple.
Regards,
Alan
This is it's position on a 71.... just forward of the right side hood latch.
The yellow hose is the supply for the wiper door actuator and is on the way to the wiper door relay.
Regards,
Alan
