Is this right?
Is this right?
I have a 68C3 with a 283ci engine in it (obviously not original equipment).
When looking at the oil filter (to get a replacement) I noticed that I can clearly see what I believe to be the flywheel. (It has gear teeth on its edge.) Is this proper or is there a cover missing?
The photo was taken from the front of the car. Oil filter is the blue object in the upper right corner.
Parodi Cigar (05-15-2018)
It should look something like this...
Good luck... GUSTO
Good luck... GUSTO
Dementer sole survivor
Received 6,254 Likes
2016 C3 of Year Finalist
you will need the cover for the 10.5" flywheel most likely. 153 teeth if i remember correctly
The teeth on that side of the flywheel are beveled that way so that the Bendix gear on the starter drive can easily engage with them.
You just need to clean that area free of rocks/debris that might damage the flywheel and install another inspection cover on the bell housing. There are several different configurations of inspection cover, depending on engine model. Most auto parts places should be able to order one for not much money.
Thanks everyone! Extremely helpful. I have contacted a transmission shop to look over my trannie and clutch (a new car to me). I will have them install the cover.
?????? your missing more then the inspection plate...looks like you missing the bottom half of the bell housing, I have never seen that before.
what transmission is that?
they did a nice job on the exhaust
Kind of think the same thing. Could be the angle of the pic but looks like more than the inspection cover is missing. Also, if you look closely, the flex plate teeth are caked in dirt. Nothing a couple of cans of Brakcleen can’t fix.
Missing inspection cover for automatic tranny....
Received 1,874 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
The second one is missing the auto trans cover. Actually easier to install because you don't have to remove starter. 4 small bolts hold it in place.
Having either one of them off wouldn't worry me a bit. I would prefer to let the heat off the clutch and the converter. I'm not driving it off road so not worried about what might get in there.
JIM
JIM
Joe, I hope that you don't think that is a '72 Corvette Coupe...
It's missing the major part of the frame the '72 Corvette came with. It does have sub-frame connectors from the front sub-frame to I would suppose the rear sub-frame. A Camaro or Deuce perhaps?
It should take a dust cover such as this plastic one that Summit sells for about $31...
https://www.summitracing.com/parts/r...yABEgKgzPD_BwE
Good luck... GUSTO
Good luck... GUSTO
Good luck... GUSTO
Good luck... GUSTO
Here’s the correct one.
Probably the same plate Joe. The Camaro shows a Turbo 350 in it while the Corvette has a Turbo 400 in it.
This cover is powdercoated and metal...
https://www.summitracing.com/parts/sum-g3883b/overview/
Good luck... GUSTO
Flexplate Dust Cover, Steel, Black Powdercoated, Chevy, TH350, TH400, 700R4
Good luck... GUSTO
Jstan2014 (06-06-2018)
Good luck... GUSTO
Good luck... GUSTO
