A/C Connector Question; w/ or w/o?
My latest purchase is a 1981 Vette with non-working AC. I see the connector to the compressor is really bubba jury-rigged and trashed.
I see 2 CONNECTOR replacements online, one WITH the diode and a pigtail WITHOUT. Which do I need for my 1981?
See:
https://www.ebay.com/itm/GM-R4-AC-Co...item3abf32d2d8
See:
The repair ac clutch connectors on rock auto don't have that diode. FYI
72and86 (05-14-2018)
I have never seen a diode in the connector for the A/C compressor on this year model.
DUB
DUB
72and86 (05-15-2018)
The diode was used to keep the electronic "pulse" from the magnetic clutch from going back to the ECM where the a/c is really controlled from on some years.
I STAND CORRECTED and had a brain fart not realizing I was replying to a 1981 Corvette.
YES...there IS a diode in the connection . This is a FACT! And It is confirmed in my factory wiring diagram.
YES...you car has an ECM ( computer). Or at least from the factory it had one.
DUB
DUB
DUB
DUB
Your carburetor has a TPS ( throttle position sensor) on it...along with mixture control solenoid. For this reason...IF you go and begin to fart around with your idle adjustment on your carb...the TPS will more than likely need to be adjusted also
As far as I know 1981 is the first year for an EMC. But I had heard that some 1980's had them...even though the service manuals do not show anything about it. I have heard that some may have ECM's in them.
DUB
72and86 (05-16-2018)
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,919 Likes
That's correct. All the '81s had ECM-controlled carb APT along with fully ECM-controlled distributors, eliminating centrifugal advance and vacuum advance. The California 1980's (all had 305 engines) also had ECM control on the carbureted vehicles a year before the Federal cars got it in '81.
Lars
