She's alive after 30 years of sitting!
Finally got this '71 454 turned over after pulling it from a barn last June. I finally got it going but she is making a lot of clanking sounds in the mufflers. Not sure if that is from sitting or a larger issue. With any luck, the video link:
Congrats 30 years is a long time to sit
I could not get the video to play
Nam Labrat
Received 4,153 Likes
30 years!
clrayjr (05-15-2018)
Mufflers
Kind Regards,
Bill
Bill, thanks for the info. I will let it run tonight when I get home from work to get it to temperature, hopefully that will help!
Definitely sounds like a baffle in muffler banging around.
Your pumping a fuel/air mix into the cylinders, and if that plug misfires then that mix goes into the exhaust system where it is ignited by the flame trail of the following cylinders. Get some good plugs in there, and ensure all the plug wires are routed to the correct cylinders, and the popping sound should go away....
Bill, there is a lot of clanking and popping while letting it come up to temperature, is that normal? Sorry for the question, it’s new to me so I thought I would ask. I appreciate the help.
Rodents sometimes store stuff in the mufflers. Clanking and popping isn’t normal when starting a C3. What have you done to the engine to get it running?
How did you determine that the points/distributor were correctly set up? I’m guessing that the problem is in the ignition. The distributor is a tooth off, the wires are in the wrong place on the distributor. I chased a similar problem on a SBC that was due to the mechanic having the spark plug wires one terminal off.
Get under the car when running. Right under the door. You will be able to tell if noise is from in front of behind you. Engine sounds pretty good. That clang is in the exhaust.
