1969 Stingray 350
6th Gear
1969 Stingray 350
I have a problem when trying to start the car.
When I first turn the key - accessories come on then I start to here the starter engage - then I lose power.
I have to disconnect the battery - wait a while and then try to start again - same problem.
checked the battery - connections - ground.
do not know where to start.
did you test the battery with a voltmeter and have about 12.75 volts?
you checked the condition of the ground under the car?
you checked the condition of the battery wire at the starter?
SO your starter is actually cranking the engine over. Correct???
But while the starter is cranking the engine...it just STOPS. Correct???
Is it an automatic or manual transmission car???
DUB
DUB
6th Gear
checked and ground wire - removed and ground down area were it connects to frame.
checked connections to the starter.
6th Gear
SO your starter is actually cranking the engine over. Correct??? (NO)
But while the starter is cranking the engine...it just STOPS. Correct??? (as soon as I turn the key - I hear the starter engage - then all power goes off).
Is it an automatic or manual transmission car??? (manual)
DUB
DUB
It sound like to me that you have a battery cable issue . Either being dirty cable ends at the battery or a connections LOOSE somewhere.
It also can be a bad a starter.
You turn the key and hear a 'CLICK'. That is letting me know that either you do not have enough power from the battery to crank the engine...or as I mentioned...there is a loose connection at the starter BECASUE...when you go to crank it. It takes so much current to spin over your starter and engine..that the loose connection is NOT allowing the current to flow.
Your car does have a clutch safety switch which makes it so you have to have the clutch pressed down to crank the car also...if it is still correct from the factory.
Which I believe it is good due to you say you hear a click.
I am betting a bad solenoid or wiring at the solenoid.
DUB
DUB
6th Gear
DUB
DUB
I am pushing the clutch in. thanks
Along with DUB'S suggestions, have you ever replaced your ground and hot cables? They are almost 50 years old. Corrosion travels inside the copper cables and eats them up over time. Then people have problems and replace parts but forget about the cables themselves. Just a suggestion. Measure the resistance of your cables to make sure they're not your problem. Good luck.
Duane
Duane
St. Jude Donor '22
if i read the thread right, sounds like a starter.
it is heating up and requiring more amps.
autozone can test it.
just a guess.
6th Gear
I am checking the alternator today at Autozone - I will check the starter as well - thanks
6th Gear
Duane
Duane
