Is this flywheel a goner?
Starter isn't engaging. I was wondering if anybody could look at these pictures and judge whether the flywheel teeth are worn down or if I can keep using it?
Your photos do not show how far down the teeth have been worn down. So..by looking a these photos it is had to say. I do see what looks like wear...but like I wrote..it is hard to say.
Also...you did not mention IF shims are being used or any other particulars such as IF you are installing a new starter.
DUB
DUB
As others have suggested- shims might be the answer. I had a couple older cars with a lot more wear than on your flexplate and the starter gear still engaged enough surface on the flexplate to start the car. See if you can move the starter a little closer. Also- DUB's question- did you install a different starter where the clearance might be affected by different mounting bolt position?
You have great advice here and I would use it. The starter shim is a great Idea, but don't forget the bendix gear bearing wear along with starter shaft wear, that will also space the gear away from the flex plate starter ring. I would use it.
Dom
Dom
Tops of teeth ground like starter too close. Made them ugly. Didnt really hurt them. Add shim.
