best clutch/flywheel for a 72 350 base
Hi, I am looking to change out the clutch on my 1972 350. I am trying to get as light a pedal as possible as I suffer from leg pain/sciatica. After reading Lars write-ups, I am definitely buying a McLeod Setup. But my question is two fold:
1. Which McLeod Clutch is best for 'lightest pedal"... the $300 Super Street Clutch or the $800 RST twin disk Clutch? Not sure I can afford the $800 but maybe if it's a major difference between the two.
2. Should I re-surface the original GM steel flywheel versus buying an aluminum flywheel ? Will that impact the pedal pressure? Pros/Cons of each?
Thanks!
JJH
Thanks!
JJH
Received 3,043 Likes
St. Jude Donor '05
You dont need a high hp clutch, just a basic LUK is fine.
Avoid the light flywheel you wont like it on the street trust me.
Any gains are in peoples heads...they will rev it in N and say "wow look its more powerZ!" but have to slip the hell out of it, deal with chattering, etc.
Jhiltonn (06-15-2018)
I agree with cuisinartvette about the use of the aluminum flywheel, there is another option also available and that is a steel flywheel. OEM over 30lbs, aluminum 11lbs, steel around 22 lbs. From the reviews that I've read the steel gives the best of both worlds. T
