1969 dash wiring harness routing
I am attempting to re-install a new Left hand dash panel back in the car. The wiring bundle seems to bind up and get in the way so the panel will not sit back where it can be attached. Where should the wiring harness be routed? The AIM shows it below the speedo/tach cables but that seems to cause problems. The gauges had wire retainers at the upper left and right as if it went above everything. Apparently the problem is I am not the first person to have ventured back here.
