Holley EFI Ignition Hook-up
I'm planning to install a Holley EFI on my 1968 327/AT. Holley says the system should be wired directly to the ignition switch. What is involved to gain access to the switch?
You don’t have to actually access the ignition switch. Just find a connection on the fuse box that has 12 v. when the ign. switch is on. There should be one labeled IGN.
talley1968 (06-19-2018)
