Best Headers
Old 06-19-2018, 04:19 PM
garyb1956
5th Gear
garyb1956's Avatar
Default Best Headers
I have a 1981 Vette with a 383 stroker motor 10.5/1 pistons and a fast burn ignition system . I've read a number of articles about which headers will provide the best performance. It's going to be just a street vehicle. I'm not looking to burn the tires coming off the line, more looking for peak performance in the mid range. Any suggestions?
Old 06-19-2018, 09:01 PM
OMF
OMF's Avatar
Most long tube headers will provide the same power boost across the board. You should do a search here and be more concerned about fit....a lot don't fit very well and need a tube dented for clearance.
With your setup, I'd look for 1 3/4" long tubes with a 3" collector.
I've had problems with Headman Elites hitting the idler arm.
Old 06-20-2018, 07:30 AM
Dennis Tapp
Support Corvetteforum!
Dennis Tapp's Avatar
Is this a Chevy 383 with fast burn heads? If so you will have a problem with the raised ports. There are a lot of unequal length manifolds for these heads but I only found one source for the equal length headers. Stahl Headers. Was not sure about the way you used the term fast burn. Never heard it used on ignition.
NewbVetteGuy (07-17-2018)
Old 07-15-2018, 10:54 AM
garyb1956
5th Gear
garyb1956's Avatar
My bad - It's a FAST fuel injection kit 30277-06KIT
Old 07-15-2018, 11:02 AM
garyb1956
5th Gear
garyb1956's Avatar
Also looking foir pug recommendations to start with AC - R44?
Old 07-15-2018, 11:14 AM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
What kind of heads are they?
Old 07-15-2018, 05:36 PM
HeadsU.P.
HeadsU.P.'s Avatar
Received 2,108 Likes on 1,619 Posts
If you have aluminum heads, you will likely need a longer reach plug regardless of which brand. And do your homework on the "heat range chart". If for instance the heat range is numbered 1-9 (one to nine) with nine being the hottest plug, another company may list the nine as the coldest plug. Its frustrating that not all sparkplug companies are on the same page.
Old 07-16-2018, 01:00 PM
garyb1956
5th Gear
garyb1956's Avatar
GM Fast Burn aluminum - P/N 19300955 62cc chamber
Old 07-16-2018, 01:03 PM
garyb1956
5th Gear
garyb1956's Avatar
Default Heads
Yes GM aluminum fats burn heads
Old 07-17-2018, 01:13 PM
NewbVetteGuy
NewbVetteGuy's Avatar
Dennis, do you happen to have a part # for the raise port Stahl headers? I'm not having any luck finding them.
Adam
Old 07-17-2018, 06:17 PM
OldCarBum
OldCarBum's Avatar
Received 4,641 Likes on 2,909 Posts
Look at Sanderson short tube headers.
3/8" flanges, 1 7/8" primary tubes,16ga mild steel, 3" collectors, aluminum ceramic powder coated inside and out.
They make more torque and horsepower, bottom end and mid range than long tube headers.
Better fitment with no clearance issues.
garyb1956 (07-22-2018)
Old 07-18-2018, 01:04 AM
claysmoker
claysmoker's Avatar
St. Jude Donor '09-'11-'12-'13-'14
Adam
Jere Stahl passed away last year. The business closed prior to that. I don't think anyone else has picked up the line. You might try a post over at Speedtalk or Yellowbullet.
To Best Headers
Quick Reply: Best Headers
