Another won't start when hot issue
#41
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Last night looking at the OP's other post he has solved the issue... what the solution was I've got no idea but I answered another question of his and put a note in there to tell us what solved the problem.
Willcox
Willcox
#42
If the problem is that the solenoid is not closing the motor contacts, which are designed to transfer hundreds of amps to the starter motor, then the only way the starter will crank is because those hundreds of amps are transferring through the pull in winding which I doubt it was gauged to handle. Alternatively, it could avoid that by having a relatively high resistance. But that means it will restrict the current enough that the the starter won't crank due to the voltage drop across the pull in coil winding.
I apologize, but I don't see the point of that jump. Jump the battery straight to the starter and it will either spin if it's good on not if it's bad or, I'll add, if its ground is bad, in which case neither the pull in winding or the starter will kick.
It does not get any deeper than that.
#43
Hopefully the new mini starter will work out. After you test...it seems that it is the problem.
Not knowing how long you have had this starter on the engine. it might be a good time to use IR thermometer and see how hot it gets. That way if you need to custom fabricate of a heat shield to protect it ...it might save you from having to do this again.
DUB
DUB
brian76 (06-28-2018)
#45
DUB
DUB
#46
I am glad that your new starter worked out.
I myself would run the car for about 45 minutes or so and without the starter blanket on it ...see how hot the starter gets. Then put the blanket on it and when the car is cold again...perform the same test d drive the same amount of time and see if the blanket is providing any benefit. Or do it vice versa. Check it when you have the blanket on it now than take it off and see how hot it gets without the blanket.
What 'gills' are you referring to?
If I am remembering correctly..the vents it the fenders are always open and are not 'gills'. It is just a single open oval hole.
Post a photo of what you are referring to.
DUB
DUB
#47
DUB
DUB
#48
I installed the new starter. With the blanket on I used the IF. The closest primary header pipe is #4. It measured at 700 degrees. Mind you, I ran the hell out of this for about 25 mins sometimes revving 5000 rpm for about 30 secs or so. I then got under the car and the IF read 480 degrees on the closest part of the starter to the primary. The furthest part read 325 degrees. The solenoid read 300. I waited 5 minutes to simulate a gas station, and it fired right up no problem. I did this a few times , and it worked great. But Man is that hot! I have to work all weekend so Monday I'll try it again with the blanket off. I'll also show pics of the side vents
#49
I agree that going down the road will aid in this somewhat. But a 'real world' scenario may be you are in stop an go traffic and thus can cause it to heat up. SO if driving and then sitting in traffic is what you encounter...that is how I would test it.
Regardless. You got the starter to work again and that is a PLUS.
DUB
DUB
brian76 (06-29-2018)
#50
i see little use for blankets and think they are beneficial for wrapping things that are hot, not things that you want to be cool.....wrap the header around the starter or use a heat shield.
do you have the front air dam in place under the radiator? if not make one and install it . this makes a huge difference in engine bay heat
#51
#52
Here is a fuzzy picture of the new starter. You can't really tell from this but there is only about a 1" gap between the front of the starter and the primary pipe. I'm waiting on 2 rolls of header wrap to come in any day now, and when I do I'll take temp readings with the IR gun again
#53
When I wrap the headers in the woven material...I do a MINIMUM of a 50/50 overlap... so in essence...there are two layers.
I buy this 'heat master' product from Kool Mat and make my own custom heat shields. Even IF the headers are wrapped in the heat tape.
https://www.koolmat.com/heat-resista...t-heat-shield/
DUB
DUB
brian76 (07-02-2018)
#54
Former Vendor
DUB
DUB
Thanks, Tim
#55
I'm just trying to figure out why these cars ran fine for 20 or more years without any 'heat soak' problems. Perhaps the [relatively new] mini-starter was the problem.
Now, starter solenoids DO fail. And when they fail, they go "Click, click click" but the starter never gets any juice. That would be the most likely cause, IMO. Could a faulty starter solenoid become heat sensitive? Maybe....
#56
I'm no expert, but you may have more than one issue that you are dealing with that is causing the starting problem.
I'm collecting parts for my 496 and probably over researching each part and componant that is going into the build.
1. My research told me to stay away from the mini starters as they don't do well with heat soak and that nothing works better than a good OEM type starter with a heat shield.
2. I had a battery ground cable that looked to be in good condition, but was heavily corroded under the insulation and was not conducting well. It may help to conduct continuity and resistance checks on your ground cables.
