Lower My C3 -Please tell me what I need
I should re phrase.... lower options without spending a fortune...
If you buy the coil over.... can you get away with just the coil/shock ... $400 or do you end up spending 2 grand?
I went with the QA1 single adjustable GS507-09450D because I have aluminum Heads intake and radiator along with lighter headlight operators. They are adjusted almost all the way down in this pic. but they are settling a bit more now that summer is here and the car is getting some use. I paid around 600.00 dollars last winter at Summit
After searching for a month
This is what I bought:
Front adjustable QA1 450 $469
Rear Bilstein HD $170
Rear bolts 8'' $22
total $661
Pleas check Summit racing review, there is a photo of grate corvette that give you a real look
https://www.summitracing.com/parts/q...model/corvette
https://www.tirerack.com/cart/HoldingArea.jsp
https://www.ebay.com/itm/1963-1982-C...53.m2749.l2649
Rear bolts 8'' $22
total $661
An extra 1-2 inch inches or so, to be honest, is not going to make any difference if my C3 has to straddle a raccoon or dead deer...no chance. Have you looked under a C3 to see how much clearance there is underneath one of these cars...NONE! My half coil cut on the 550 springs lowered the front end 1.5 inches and I can live with that reduction since it is really very little since the car is very low to begin with. About the only animal that these cars can straddle is a chipmonk, squirrel, or mouse.
Correct!
I cut 1/2 coil off aftermarket 550 springs 1 inch lower than the Stock OEM GM 550 springs and there was no difference in the ride quality with the Bilstein HD's before and after the cut>>>>No issues with the front alignment or any rubbing issues.....it is low though..............But handles so much better!
You sure that you do not have any front brake caliper issues or worn suspension components like tie rods, ball joints upper and especially lower ball joints, upper and lower control arm bushings as well as steering box play. I doubt it is just an alignment issue. Everything needs to be in perfect shape...
new ball joints, new control arm bushings, and rag joint seems good. Car drove straight before lowering it
Hi Guys, I cut one coil off the front which lowered it by 1 3/4" and went with C4 10" bolts and cut them down to 8 1/2" drilled them for a split pin and castle nuts(make them look a bit stock!!)
Just curious, guys who have cut their springs and what not (not gotten a coilover package), how do your shocks hold up? With other cars they tend to blow out quicker with a lower ride height. TIA.
#34
GW Lower Control Arms?
Forum: Any thoughts about the GW Control Arms?
Many of us would like to do a 2" drop or more in some cases.
This sounds like a good idea.
Suspension travel is a good thing for comfort! lol
R
R
#35
