Vintage Air installation questions
Like to get some input on the installation of a vintage air system in a 1976 Corvette with Factory air. How easy is it to install and what is the the most difficult part. Also how well does it really work. I live in Florida and the heat here is really hot in the summer. I will keep up with the heat and does it make the car overheat.
Getting your old AC system out will probably be the hardest part of the process. You will have to remove the dash pad and center gauge bezel and all your original parts. The center console will have to come out to modify the controls. The engine side of the AC system isn’t easy either, but if you aren’t saving it then you can use a little more muscle to get it out of the engine bay. Once all your factory stuff is out of the way, installing the Vintage Air components is pretty straightforward. The hardest remaining part is getting all the wiring and new ductwork to fit behind your dash pieces. Sometimes the ducts get a little crushed getting the dash pieces to line up correctly.
I agree with maj75. The ducting was the most difficult part for me to get situated correctly and still have full A/C performance through the upper vents. It's a tight fit behind the center gauge cluster and I had to assemble/dissasemble it several times before I got it to fit reasonably well and not crush the vent ducting. As far as performance goes, it cools really well with my tops on and certainly takes the temps down to bearable with them off. I live in southwest Utah with 100+ for most of the summer and it works great. I've never had any overheating issues and it's a 69 big block car with some HP mods. My coolant temps never get above 190-200.
Air
My car originally came with a c and I read the whole system. After doing that it didn't really work too good it made it comfortable but the older compressor really takes away a lot of horsepower almost stalls the motor when you turn it on and it doesn't cool too well. I was skeptical to invest more money into it and have a system that didn't do a good job. Thanks for your input
Compressor bracket
I had a 1974 factory BBC with A/C. Restored the A/C system 15+ years ago. New actuators, seals, heater core, evaporator core, compressor, condenser and changed the VIR to CCOT. It wasn't any colder and didn't blow any harder either. So a few years ago a Vintage Air Sure Fit system was installed. We also replaced the ragged transmission tunnel insulation, pulled the carpets and Lizard Skined the floor board and firewall. The hardest part of the job was removing the orginal evaporator from the engine bay with the BBC. The results were better than expected. I now get cold in this car on a +90°F day. I believe between moving the evaporator to the interior and insulating the car better, gave me the car I want to drive any day. In retrospect, I wouldn't had wasted the time and money restoring/modifying the original A/C system.
Compressor
You can split the difference. Your 76 is comfortable now but you don't like the compressor. Change the compressor to a Sanden 508 and make new lines to connect to your current system, maybe even replacing your stock condenser with a new multipath, and see if this makes your 76 feel 'right'. If you find that you want more improvement, THEN remove and replace the rest of the system. If you do this, and go with the full system replacement, the maximum additional cost would be would be to fabricate a second set of refrigerant lines. On the other hand, you may find you're satisfied with replacing the compressor and have what you want for MUCH less work and money.
I won 900 in in the Florida lottery yesterday so it is basically free. Life is good
Nam Labrat
Received 4,153 Likes
Sanden (beware of counterfeits) is a great compressor. After a few minutes of cooling the interior I never had to set the sliding lever more than halfway to keep the interior very cool on a 97*F day in traffic. On open roads I could set it to less than halfway.
Let a quality A/C shop install the unit for you.
I'm about half way done with my Vintage Air NOT SO sure fit system. The defroster ducts eliminate the bracket that holds the upper center console vents in place so I am trying to figure out a way to fix that. I think I can drill a couple holes in the face and attach to the dash. The Tubes just barely make it through the firewall and it was difficult to get them into the 4 holes in the plate. It is going to be a challenge getting the lower one connected. One inch longer would have been nice. I had to cut the Grommets to get them on. The bottom holes for the condenser brackets don't line up with the holes on the radiator mount. I reamed out the holes to make it work. The drier hits the mounting where the Headlight Vacuum canister is. I had to cut some off the bottom of the canister mount to get the drier in. It is not an easy installation my any means. But then I never expected it to be. I just hope it all works once I'm done, LOL.
Works goods
A few other minor upgrades you may want to try to improve that are installing some DEI insulation to the evaporator case under the hood to help shield it from the heat coming off the engine. From LastBigBlock's thread:
This same type of insulation has been used by several members here to insulate the firewall and transmission tunnel. Many of the OEMs have this insulation installed from the factory to improve the performance of the HVAC system, sadly, our Corvettes were not graced with this. Sure it adds a little weight to our sports cars, but the DEI insulation is pretty light for the amount of improvement you can get on interior temp. I'm in Texas and our summer is a good 6 months long it seems, so you can bet I'll be insulating the heck out of mine as I go back together. I want to see 45 degree or better air coming out of the vents!
i installed vintage a/c in my 76 l48 easy install the hardest part is getting the shifter console back in cools the car perfectly in sw florida heat no overheat issues no loss of power very happy of course to whileiamat it got me so new carpet seat belts heat barrier parking brake and shifter consoles are in floor mats and new window tint hell might as well do door panels to
2 year old thread......
