1970 350/300 fuel requirements - CorvetteForum - Chevrolet Corvette Forum Discussion
Old 07-13-2018, 09:31 PM
the70shark
Junior Member
Default 1970 350/300 fuel requirements
If I run Gum-Out or some equivalent through the engine, followed by an oil change with Slick50; can I use unleaded premium without any problems?
the70shark is offline
Old 07-13-2018, 10:04 PM
Hammerhead Fred
CF Senior Member
Hammerhead Fred's Avatar
Should run on unleaded premium without doing either of those two things.
Hammerhead Fred is offline
Old 07-14-2018, 07:00 AM
2mnyvets
CF Senior Member
I have a 350/300 with a 350/350 cam and have been running unleaded premium for the 30+ years i have owned it. No problems. I think you are talking about an oil flush and an oil change with additives. Not sure how this would help fuel issues. For the oil, I would use a high zinc content oil if you are running the stock flat tappet (or any flat tappet) cam. Off-the-shelf oils don't have the zinc content they once did and don't protect the cam as well as the older formulation oils. Are you having fuel issues?
2mnyvets is offline
Old 07-14-2018, 10:06 AM
Dynra Rockets
CF Senior Member
Slick50
they still sell that stuff?
Dynra Rockets is offline
Old 07-14-2018, 10:46 AM
the70shark
Junior Member
lol :-)
Old 07-14-2018, 10:50 AM
the70shark
Junior Member
Really, good to know; as you might guess, I have not owned a vehicle that use to run on leaded gasoline. And have also heard you need to use a lead additive or install a 'conversion kit'. Thank you for a quick reply.
Old 07-14-2018, 10:51 AM
the70shark
Junior Member
Good to know; as you might guess, I have not owned a vehicle that use to run on leaded gasoline. And have also heard you need to use a lead additive or install a 'conversion kit'. Thank you
Old 07-14-2018, 12:36 PM
fishslayer143
CF Senior Member
My question is why would you put Slick 50 in it? ask any rebuilder what that crap does to the inside of your block. use a quality motor oil suitable for flat tappet cam and leave the snake oil to salesmen
fishslayer143 is offline
Old 07-14-2018, 01:47 PM
the70shark
Junior Member
OK, thanks for the input; much appreciated.
Old 07-14-2018, 01:49 PM
the70shark
Junior Member
Thanks did not know about the "zinc content" you mentioned.
Quick Reply: 1970 350/300 fuel requirements
Sponsored Ads
Vendor Directory
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
