Passenger door won’t open
my passenger door is not opening anymore. After doing some research it seems like I need to replace the whole inner door mechanism. Any tips on how to do this? Found the parts that I think I need. Posted below.
http://www.corvetteamerica.com/catal...1%2C1882%2C304
Received 1,244 Likes
Hi and Welcome!
You probably don't need all those parts.
Roll the window down and push down on this part.
Once you get the door open remove the door panel and photograph or describe what you see and someone will guide you.
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
And here is another picture of how to get the door open when it's stuck... the fail safe lever will work even if the door is locked, the issue is getting to it with a long screw driver and depending on the year of the car you may have to bust through the anti theft shields.
