Rebuilding Windshield wiper arm linkage
Anyone rebuilt the linkages that connect the motor to the wiper arms? Mine has a lot of slop and I think is the main reason I can't get my drivers side wiper blade from going past the A pillar even though I set them up correctly per the AIM. I got it better yesterday but then the blades would hit each other when sweeping down and where they are the closest. I adjusted the passenger side up some so they wouldn't hit but then had to adjust the vacuum safety switch to allow the door to close. I can see that the door hits the passenger arm slightly and if I didn't have 47 years of ware on the linkage.
http://repairs.willcoxcorvette.com/1...rm-adjustment/
Thanks but I've done all that. I'm talking about slop at the attachment points where the linkage meets the wiper blade arm itself. I have a lot of slop that cannot be adjusted out.
Don't know from description, but I had a problem with my driver side wiper hitting the passenger side and could not adjust it out. Then discovered the threaded stud that the wiper arm mounts onto was moving on the post. Needed to drill a "keyhole" and screw a small screw into the hole that I created between the post and the threaded stud. Threaded stud does not move now and wipers fixed. Hope the description helps. Mine is an 82. Don't know how the mounting post hardware is set up on other models.
Don't know if it's sold as an assembly for our cars anymore, but you may be better off just replacing the whole wiper linkage transmission (if you can find one) if there's wear in it. Not a hard job and will work like new when done. I had to do this 2X on my son's car because he's too lazy to brush the snow off the windshield. Easier just to turn on the wipers and hope they have the power to push the snow off. The last wiper transmission I removed, I beat him with when I got it off. He got the message.
Duane
Duane
slofut (08-12-2018)
I took my 73's apart. You do this by tapping on the bottom of shaft. There are two bushings and a brass lock. The top bushing is a flanged bushing. The bottom is just cylindrical. There are at least three possible issues: If yours has side-to-side movement, the two bushings and possibly the shaft is bad. If it has in-out movement, the brass lock/lower thrust may have come loose. This is just a brass cylinder that has an undersized ID. The lock is pushed onto the serrated portion of the bottom of the shaft and it is an interference fit. This lock controls the in-out movement. The third possibility is a bent shaft.
Can you see which if any, of these conditions you have?
MY issue is blade chatter when it's just light rain/drizzle.......heavy rain is no chatter in either direction.....
what causes that, and can it be fixed or is it an act of GOD to do it?? car is a '72 I have the door set up so it's easy to remove, so no sweat there.....
I get that too on my 78
If I adjust the vacuum safety switch down a bit to make the wiper go down further it won't push the vacuum switch enough to allow the door to close. I can see play in both linkage to wiper arm attachment point and I think if I eliminated that or at least make is less everything should adjust back in place. .
Thanks 2mnyvets
Yes I've been through all of that. The vacuum safety switch is working fine as is the whole system. I don't have enough adjustment either at the a-pillars or if I get that adjustment close the park position of the right blade is a little higher that were it should be. The only thing I can see causing this is my excessive play where the linkage connects to the wiper arms. I could figure out a bushing/bolt setup but if there is a better/correct way to rebuild the linkage I would rather do that.
Keep it coming. Surely someone over the years has tackled this. We just need to find him.
