Tighten up stock shifter - CorvetteForum - Chevrolet Corvette Forum Discussion
Old 08-20-2018, 09:39 AM
Jerrys80
Junior Member
Jerrys80's Avatar
Default Tighten up stock shifter
I have an 80 corvette and my stock manual shifter feels loose or sloppy for lack of a better word. I have considered going aftermarket but I do like the original one. How would I go about making the original feel solid, or is this possible? I have looked at Hurst but it doesn't look like they make one for the 80 - 81 anymore. Any help on how to tighten up the original or ideas on what others have used aftermarket is appreciated. Thanks.
Jerrys80 is offline
Old 08-20-2018, 10:19 AM
Iceaxe
CF Senior Member
Iceaxe's Avatar
Start with a shifter rebuild kit.
https://www.zip-corvette.com/77-81-4...RoC11gQAvD_BwE
Iceaxe is offline
The Following User Says Thank You to Iceaxe For This Useful Post:
Jerrys80 (08-21-2018)
Old 08-21-2018, 05:26 AM
Rescue Rogers
CF Senior Member
Support Corvetteforum!
Rescue Rogers's Avatar
2016 C3 of Year Finalist
check for wear in the linkage like the holes to being opened up or the rods being cut into. The rebuild kit will tighten it up if the rods are still in spec. Put the the rods in the upper hole at the tranny and the throws will be shorter too
Rescue Rogers is offline
The Following User Says Thank You to Rescue Rogers For This Useful Post:
Old 08-21-2018, 07:26 AM
Jerrys80
Junior Member
Jerrys80's Avatar
Thanks Iceaxe and Rescue Roger, I appreciate the help.
Jerrys80 is offline
Old 08-21-2018, 07:52 AM
Hammerhead Fred
CF Senior Member
Hammerhead Fred's Avatar
If it's worn alot try taking a look at this previous rebuild thread. https://www.corvetteforum.com/forums...-question.html
The rebuild kit helps but resquaring the shifter "box" really makes for a nice original feel.
Hammerhead Fred is offline
The Following User Says Thank You to Hammerhead Fred For This Useful Post:
Old 08-21-2018, 09:28 AM
Jerrys80
Junior Member
Jerrys80's Avatar
Thank you. I will definitely look through that. I appreciate the help.
Jerrys80 is offline
Old 08-21-2018, 10:47 AM
DUB
CF Senior Member
First you have to identify WHERE the problem is at.
I can say that on about 99.9% of the shifters I tighten up I do not need to buy any parts.
On rare occasions the shifter linkage may be worn so the hole in the shift levers are fine but the rod itself has excessive front adn back play in it.
Make sure you use or replace any worn 'G: clips that holds the rods to the shifter levers. If my memory serves me correctly there is only ONE plate where cotter pin is used adn that is to secure the clevis pin. So using cotter pin to hold on all of your rods is not correct and you can get side movement in them and throw everything off when you go to set your NEUTRAL GATE.
Now....I know many have used flat washers and forced a cotter pin and used it that way and kept the rod from rotating...so do as you wish. They still make and sell the correct 'G' clips so that is what I use.
SO...IF your levers that are in your shifter with the rods connected to them have a lot of side to side play and can wiggle. Then I would take out the shifter and put it in a vise and slowly being to crush it inwards to get it so these levers can slide but have very little to no side to side play. Now when I do this it may be a 'hit or miss' if I can get the box closed up enough to my liking or if I need to take it apart...which for me is no big deal and not hard to do. Then when I feel I have got is closed up enough I re-assemble it an check it and if I went o far I can easily spread it back apart.
At this same when I have one of the levers in the shifter I check the DEPTH of how far the end of your chrome shifter handle actually fit in the notch it needs to fit into. I have often times needed to weld and EXTEND the end of this handle so when I use my line up tool for the neutral gate setting. I KNWO there is PLENTY of steel contacting the notch of the lever.
I have seen brand new shifters that were ground down too far an I had to add metal. Also when I am adding the metal at the end of the shifter handle...I grind and shape it to fit nicely in the notch on the lever so I do not have excessive movement in the shifter handle to the notch in the lever because I made it to narrow from front to back... so I am going my customer a really nice shifter.
Because if you stop and think about it ....years and yeas of the shifter being slammed to one side and then the other has caused for the box to widen.
DUB
DUB is offline
The Following User Says Thank You to DUB For This Useful Post:
Old 08-21-2018, 10:54 AM
Jerrys80
Junior Member
Jerrys80's Avatar
DUB
Thanks for the help.
Jerrys80 is offline
Old 08-21-2018, 12:07 PM
Rescue Rogers
CF Senior Member
Heres a write up from last winter when I rebuilt mine.
https://www.corvetteforum.com/forums/c3-tech-performance/4107838-rebuilding-a-muncie-4spd-shifter.html
The Following 2 Users Say Thank You to Rescue Rogers For This Useful Post:
GUSTO14 (08-21-2018), Jerrys80 (08-21-2018)
Old 08-21-2018, 12:52 PM
GUSTO14
CF Senior Member
GUSTO14's Avatar
https://www.corvetteforum.com/forums...d-shifter.html
Great write-up and pictures Scott, thanks for posting that.
I can't believe I missed it, I guess I need to spend more time here on the C3 Forum...
GUSTO
GUSTO14 is offline
The Following User Says Thank You to GUSTO14 For This Useful Post:
Rescue Rogers (08-21-2018)
Old 08-21-2018, 01:12 PM
Jerrys80
Junior Member
Jerrys80's Avatar
That definitely helps.
Jerrys80 is offline
The Following User Says Thank You to Jerrys80 For This Useful Post:
Old 08-22-2018, 07:02 PM
Lagonia
CF Senior Member
Lagonia's Avatar
When I got my Vette last year, that is the first thing I rebuilt - the shifter - it was way too loose. It did improve but not to the point where I liked it. It wasn't long after that when I put in a 5-speed Tremec tranny. That solved *all* kinds of problems, including the loose shifter.
Lagonia is offline
The Following User Says Thank You to Lagonia For This Useful Post:
Jerrys80 (09-04-2018)
Old 08-23-2018, 08:44 PM
Rescue Rogers
CF Senior Member
I'm jealous
Sponsored Ads
Vendor Directory
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
Question Title:
Description:
