Need 'Hub Centric' Wheels or no? Pics attached
#41
Received 3,043 Likes
St. Jude Donor '05
Had 2 sets of aftermarket rallyes that were lug centric no matter what I did they vibrated, lugs came loose. Not safe imo...
Finally broke down and bought some hubcentrics, problem solved. I know guys in the 70s down the st used lug centric rockets, cragars etc some complained, some didnt.
Not saying ones right or wrong but the lugcentric seems safer. Its "located" then clamped tight, whereas the non L.C the lugs do all the work and carry the weight .
If you have vibration probelms (common with aftermarket stuff) spin them on the balance machine and check runout before you mount the tire. You may be surprised...
not sure how an oem wheel can be perfect but an expensive aftermarket are way off the mark. Machine may say "balances within spec" but in fact it will cause issues. Same with tires, watch the treads as they spin, dont want that side/side variance, it will trammel and eventually come apart
#43
as the wheel rolls the load on the studs changes form one side to the other in the simplest form
This will tend to flex the stud
there is a lot of different stresses on the wheel studs .
the dynamic load generated by the movement of the car in corners van be considerable, braking and pot holes etc all add to fatigue.
what happens when you keep bending a piece of wire.
The wheel studs take a lot of stress in normal road use a concentric hub wheel will reduce the load to some extent.
a press fit was suggested in and earlier post , that would be the optimum set up for extreme usage.
The best precaution owners can take, is to keep the wheel retainers regularly torqued up, for road use , the manufacturers have recommended specs
#44
OK, just checking how badly out in left field the last 4 or 5 posts have gotten. The studs don't carry a shear load. The weight of the car certainly is not constantly bearing sideways on the studs. The studs clamp the wheel to the hub face and the friction between the wheel and hub face carries the load.
#45
Those of us with true hub-centric wheels (where there's a tight, interference fit after tightening the lugs) have the entire hub to bear the loads of the weight of the car and the forces of a bumpy road.
#46
Received 1,874 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I will 100% agree that a nice hub centric assy would be best....but there sure are a lot of racers out there with lug centered wheels doing pretty well. I've got several wheel sets for my car to do various things...and a couple require spacers...and most of them use shank type lugs and one uses conical style. The others are some GM Rally's that do fit a little tighter on hub,,,,but still use conical lugs. Anyway...never had an issue whether drag racing and pulling wheelies or running 200 MPH at TX Mile.
As mentioned...since it's turned into a technical discussion.....18 wheelers have used stud mounted wheel assy's forever. These days you see most are hub piloted...but both designs will have issues if not torqued properly. Much of the hub piloted design with the captured washer and procedures requiring oil between washer and on threads vs dry on earlier stud piloted styles...allow MUCH more clamping load with same torque spec. I can also tell you the wheels and brake drums on the hub piloted truck stuff doesn't fit all that snug to the hub. In fact...the drums are pretty sloppy and one of the tricks to a smooth ride and no balance issues is to step on brake pedal to 'center-up" the brake drum before making final wheel tightening. They also make centering devices to install on lugs to center "hub piloted" wheels off the lugs before tightening.
JIM
JIM
#47
From discussing this topic over and over.....
The loads on a wheel when you're on a bumpy road are far in excess of what "friction" will withstand. Even with the lugs properly torqued.
#48
JIM
JIM
#50
Proof, or more conjecture?
I thought it was quite well known and accepted that the wheel being clamped against the hub was what held the wheel in place, but apparently it's not understood at all.
Now, you're claiming every time there is a bump the wheel shifts until the center hole hits the hub flange? It will have to move, because the wheels do have clearance between the hole and hub flange. C3 wheels are not an interference fit, unless they're left on long enough to corrode into place. There wasn't an S10 made with interference fit wheels supplied from the factory. C6 5-spoke wheels certainly aren't an interference fit either. Wouldn't that constant moving cause fretting and wear on the surfaces that are moving against each other? Where are the pictures of this wear from the wheel moving?
#51
Here is a funny thing.
After I read through several threads on this forum and was convinced I "HAD TO HAVE" hub-centric wheels for my 73, I called numerous wheel manufactures and my first question was "are your wheels hub-centric or lug-centric" and their response was always "what", we don't manufacture any true hub-centric wheels.
There was a couple wheel manufactures who would custom build one off hub-centric wheels at the price of about $2,000.00 each.
Some of the manufacturer's told me that I could have custom spacers manufactured that would duplicate a hub-centric wheel set up but none of the wheel manufactures mass produced any true hub-centric wheels or the spacers to duplicate them.
I thought for sure I would have to sell my Corvette because I could not run wheels that would wobble, cause vibrations and shear off if I gave it a little throttle.
The wheels I purchased for my 73 are top of the line, from a top manufacturer, built here in the USA and lug-centric wheels.
But according to the manufacturer, that's the way they have built them since the 60's, just like Fred Flintstones.
And believe me I must have called them all.
gbarmore (09-26-2018)
#52
The original poster is going to add 1/4 wheel spacers. I'd be more concerned with the spacers than not having hub centric wheels.
Suppose there are those out there that use wheel spacers and not have problems. I've have never used them and plan to keep it that way.
#53
Back when I purchased a set of the "first generation" CCWs, the ones with the BBS "crosslace style" centers, they sized the center bore of these wheels to the hubs of the car. Therefore, they were "hubcentric". When I bought a set of CCW Classics for my C-5, I asked if they were hub centric, they told me that they "sized" the ID of the center cap to the hub of the car the wheels were being used on, and combined with a snug fit of the OD of the cap, to the center bore of the wheel, they were a "quasi-hubcentric" wheel. I later sold them, and bought a set of BBS LM wheels, for that car. Believe me, they are a very tight, hubcentric wheel....
#54
My S10, the Bravada that I owned before that, all the Mercedes Benz cars I've owned (mostly W126 and W124 cars) and all the VWs and Audis I've owned, along with several others (Volvos, Saabs, etc.) have all had true hub centric wheels. I really can't remember the last "factory" wheel I removed from any car that wasn't hubcentric. For aftermarket wheels, I always recommend adapter rings to make them a snug hubcentric fit. I've seen various problems (mostly vibration/shaking, lugs that mysteriously loosen themselves) with aftermarket wheels installed using only the tapered lugs to center the wheels.
I have seen the galling you've referred to, but only on cars without hubcentric wheels. My S10 had a set of aftermarket wheels on it, and for the first few months I had it, every couple weeks, I'd have a vibration/shake when driving, and I'd check and find one of the wheels was loose (lugs worked loose). Those wheels fell off the thing when I took the lugs off. The center bore was significantly larger than the hub. When I bought new tires for that truck, I put a set of factory wheels on it (from the local pull-your-own parts yard) and never had an issue with loose lugs again after that. When I pulled the aftermarket wheels, I did notice some galling in between the hub flange and the back side of the wheel flange. Things were definitely moving there. BTW, I got some adapter rings machined for those aftermarket wheels, and I put them back on recently. I haven't had any issues with loosening lugs with the adapter rings installed, and when I swap wheels/tires, after removing the lugs, it takes the same forceful tug as the factory wheels to dislodge the after market wheels from the hub or adapter ring (depending on which joint releases first).
#55
Well, when I remove the tight nuts from the FACTORY C6 5-spoke chromed wheels that are on the FACTORY C6 suspension system including the original wheel bearings that I have sitting in my garage on the hoist, the wheels falls loose as I remove the last wheel nut. No tug required to get them off, let alone requiring hitting them with anything. So, I call BS on those wheels having an interference fit. Today, I'll leave you with this picture that shows a 0.008" feeler gauge stuck between the hub and the wheel center while the wheel is bolted to the car. Rather hard for the wheel to be an interference fit to the hub flange with clearance between the parts.
If these wheels moved around every time they hit a bump like you claimed, they'd be moving at least 0.008" back and forth all the time. That seems about as right as expecting the clearance between parts to magically go away.
I can hardly be bothered, but if you feel the need to continue with the bogus claims about C6 wheels then I'll take a video of the wheel falling loose when the last lug is spun off to further prove you're full of it.
#56
Happy Friday all. So I bought one American Racing AR767 Steel Wheel (https://www.summitracing.com/parts/are-ar7675861) to mount up my MT E/T Street tires and test fitted them for clearance today without the tire. I'll need a 1/4" spacer to clear the calipers due to the 1/4" more backspacing on these wheels, but the real question is, do we need "hub centric" wheels for our C3's (1980)? The original rally wheels appear to mate up tight with the hub, the AR wheels do not. OK, not OK, disaster waiting to happen? AR767's have a Center Bore Diameter of 2.858 in.
Appreciate any advice!
ARinfo <arinfo@wheelpros.com>
Thu 9/27/2018, 3:27 PM
You
Greg,
Thank you for your purchase. The AR767, and all aftermarket steel wheels, are not designed to be hub centric. They are designed to be centered on the vehicle’s lug nuts. They use push thru center caps that prevent them from being hub centric. As long as the wheel is tightened in the proper way the wheel will function properly.
Thank you
Sent: Wednesday, September 26, 2018 8:19 AM
To: ARinfo <arinfo@wheelpros.com>
Subject: Someone contacted you on American Racing
Sent on: 26-Sep-18
Country: US
State: WI
Message:
I have a 1980 Corvette and I purchased your American Racing AR767 Black Wheels, part #AR7675861 for it. Once I received them I realized that they are not 'hub centric', or that the hub cutout is larger than the hub on the car. Therefore the only thing centering the wheel are the wheel bolts and lug nuts. Is this wheel designed to locate properly with this set-up or do I need to look at a different wheel set-up with the proper hub size so it locates by the hub and not by the wheel studs?
Thanks, Greg
lionelhutz (09-28-2018)
#57
…..Thank you for your purchase. The AR767, and all aftermarket steel wheels, are not designed to be hub centric. They are designed to be centered on the vehicle’s lug nuts. They use push thru center caps that prevent them from being hub centric. As long as the wheel is tightened in the proper way the wheel will function properly.
gbarmore (09-28-2018)
#58
I bet the aftermarket ignores hub centric to avoid having to stock different offset and hub bore combos. A giant hole in the middle of the wheel makes it fit any hub.
I have run hub adapter rings on my Lexus and gone without. I feel more peace of mind knowing the hub is sharing the load with the lugs but nothing bad happened when I drove for a few months without the adapter rings.
I have always wondered what would happen if some distracted kid doing a tire rotation ended up with two spacers on one wheel. The wheel would be held away from the hub flange. I’m sure it has happened since the adapter rings seem to stick in the wheel sometimes and on the hub other times when the wheel is removed.
#59
Nice answer, direct from the manufacturer. Notice the all aftermarket steel wheels are not hubcentric comment. Tighening the 5 nuts properly will clamp the wheel to the hub face so tight that it will never move. The wheel was never designed to ride on the center hole because it's not necessary.
Of course, the naysayers will still never believe an answer direct from the manufacturer....
#60
