Trouble finding thin head gaskets?
Old 10-01-2018, 02:37 PM
gkull
gkull's Avatar
Received 1,329 Likes on 1,057 Posts
Default Trouble finding thin head gaskets?
I think that my head gasket was a Cometic MLS .021 compressed. It has to work for aluminum heads. Summit sells a .027 for a 4.030 bore. I'd even use a .015 if I could find it. What is your favorite for aluminum heads.?
https://www.summitracing.com/parts/c...make/chevrolet
Old 10-01-2018, 03:30 PM
The Money Pit
The Money Pit's Avatar
Usually Felpro Permatorqs, but I had been looking at Cometics recently. Poke around on their site, maybe call tech support to get the right one.
http://www.cometic.com/i-24768120-gm...bore-each.html
Old 10-01-2018, 10:07 PM
Buccaneer
Buccaneer's Avatar
Location: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
Received 1,004 Likes on 688 Posts
I use Cometic MLS with my Dart and AFR heads, NEVER an issue.
Old 10-01-2018, 10:13 PM
Vette5311
Vette5311's Avatar
Received 1,255 Likes on 838 Posts
Default Felpro
Thin with coating. I think maybe 1094?
Old 10-02-2018, 06:41 AM
Dynra Rockets
Dynra Rockets's Avatar
I used GM factory 1990/1991 MLS head gaskets for my aluminum head install. No issues after 3 years of use. I've got it written down somewhere but from memory they were .028 thick.
Old 10-02-2018, 12:35 PM
Surfer69
Surfer69's Avatar
I like this one. 0.026
https://www.summitracing.com/parts/cle-5746
Old 10-02-2018, 01:05 PM
NewbVetteGuy
NewbVetteGuy's Avatar
The Felpro 0.015" SBC gasket is 1094.
It no longer has the black coating on it; it's now clear and EVERYTHING ON EARTH will stick to it -dust, hair, dirt -keep it in the bag until right before you install it. It's like a magnet for crap that you don't want on your head gasket.
The Felpro gasket catalog says it's appropriate for Iron or Aluminum heads.
Adam
The following 2 users liked this post by NewbVetteGuy:
68post (10-06-2018), gkull (10-03-2018)
Old 10-02-2018, 04:15 PM
Crimson Thunder
Crimson Thunder's Avatar
I use 1094's with my AFR heads and never had a problem.
gkull (10-03-2018)
Old 10-03-2018, 02:21 PM
gkull
gkull's Avatar
The only problem is they are made way bigger than the bore. 4.100 Vs. 4.030 for the cometic
Old 10-03-2018, 03:03 PM
NewbVetteGuy
Whats the concern there? Just the tiny loss in CR or something else? (I’m using it on a 4.000” bore, so curious.)
Adam
Old 10-03-2018, 04:39 PM
gkull
gkull's Avatar
Adam
The problem is less material between the cylinders and water jacket. I just measured the distance between cylinders @.370 inches 4.100 - 4.030 = .070 larger than my bore. Then add another .070 from the next cylinder and you have .230 inches of gasket between cylinders. That is less than a 1/4 inch. I've had two head gasket failures on my Vette. Detonation from low octane fuel being sold out of the 93 octane super unleaded pump. I turned them into the state and testing showed that they had 87 octane in all their pumps. They got a fine! But it didn't help my vette which had a very high DCR. I had antifreeze coming out the exhaust pipe on one side. The second was my fault for not retorquing the head studs after a few heat cycles using copper head gaskets. That one blew between cylinder 3 & 5 like an inch was missing. I was racing around a track running it with my foot on the floor for the 3000 foot long main straight at the Miller race track and down towards the brake area the motor started sounding funny
Other than minor loss of compression, I would rather have as much gasket as possible right up to the cylinder edge.
Old 10-03-2018, 05:07 PM
NewbVetteGuy
Did NOT know that... These guys make a 0.015" thick shim gasket for 305s with a 3.960" bore -just open it up to 4.030"???!??... (I'm guessing that's not a great idea for some reason...)
http://scegaskets.com/store/chevrole...or-sbc-511961/
Adam
Old 10-05-2018, 12:06 AM
SFOcean
SFOcean's Avatar
Cometic will make anything you need;
https://www.cometic.com/if-6406-custom-orders.html
Old 10-06-2018, 01:30 PM
cardo0
cardo0's Avatar
Location: Las Vegas - Just stop perpetuating myths please.
I think a thicker gasket for sealing is more important than the benefits of quench or a little more compression. You can always use race gas on race day and keep RPM's low/below 4000 while on the street.
Yes the solid copper gasket will leak a tiny amount regardless of torquing. There maybe a optimum surface roughness to use copper gaskets but I don't know what it is. I understand the benefit of copper gaskets is for reuse on race cars (mostly drag cars) that have the heads removed frequently.
Old 10-08-2018, 11:31 AM
gg521
gg521's Avatar
The most important thing is quench distance. This is the distance that the piston sits down in the bore to the cylinder head. This distance should be around .039 to .040 or there abouts with the gasket in place. The less down in the bore, the thicker the gasket should be and vice versa.
Old 10-08-2018, 12:30 PM
Vette5311
Vette5311's Avatar
Default ???
I have often wondered about this, what is optimum. Can you tell why this number is best? Just wondering why more or less is not as good.
Old 10-08-2018, 02:26 PM
jim2527
jim2527's Avatar
More doesn't propagate flame travel as well and less doesn't leave enough room for proper clearances. There was a good discussion on Speedtalk. 40 isn't always 40. Using simple math as an analogy which is better, A or B when the second number is gasket thickness?
A. 5+35=40 piston .005 in the hole with .035 gasket
B. 30+10=40 piston .030 in the hole with .010 gasket
The consensus seemed to be they'd rather have B, piston more in the hole with a thinner gasket.
Vette5311 (10-08-2018)
To Trouble finding thin head gaskets?
Old 10-08-2018, 03:12 PM
NewbVetteGuy
Interestingly enough, FelPro says that the steel 0.015" shim gaskets CAN be used with aluminum and just leave it at that.
I noticed that Holley / MR gasket has a very similar steel shim gasket and they have a very prominent warning on them that says that they can leave imprints in aluminum heads.
Here's the warning from Holley / Mr Gasket: "Steel Shim Gaskets are not recommended for use w/ aluminum cylinder heads since the endorsements in the gasket will cause indents in the deck surface of the heads."
Adam
Old 10-08-2018, 03:16 PM
NewbVetteGuy
Jim, any chance you still have the link to the Speedtalk thread on the subject? Because that's really interesting and kinda blows my mind. I can't understand why the thinner gasket would be preferred other than the fact that the gasket's inside diameter is often way larger than the actual bore size...
Vizard had a good rule-of-thumb on how much power increase you get from a decreasing quench (assuming due to a faster burn); but I didn't save it....
If I remember right the "ideal" / "safe" piston to head clearance is also based upon the rod and rod bolt that you have and the RPM that you plan to spin, right? (Lower RPM with less stretchable rod materials / designs can safely have tighter piston to head clearances)
Adam
Old 10-08-2018, 03:18 PM
NewbVetteGuy
Any idea just how horrible the premium is to have a custom gasket made?
Adam
Quick Reply: Trouble finding thin head gaskets?
