Removing the button pin from tach drive
Hi all, I’m working on my 72 454 4 spd distributor and I want to replace the nylon button for drive gear that looks like it is no longer there. But the small pin in the rear is there. How do I get this out. Is it a set screw with Allen head or a drive pin? Should I punch it out with small punch? I already ordered nylon button and gear w washer.
hope the rest of the project goes smoothly
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
You can check this on a distributor machine and the key is to check the dwell while the distributor is spooling up. When you spool up the distributor either in an engine or on the machine if the dwell opens as you rev it up, then there is an issue with the upper bushing.
The other issue is if the cross shaft is bad in the distributor then the main shaft is more than likely bad. So don't replace the cross shaft without replacing the main shaft.
Now... while upper and lower bushings are available, and so are the installation tools.... Most don't have the correct ream to run through the bushings once they have been installed. When you install new bushings even with the correct installation tool... they will compress.... so the ream is monumental in making sure the clearance is correct for the shaft and bushing. We sell the heck out of the bushing kits but how these people install them correctly I have no idea (unless they have the correct ream).
