Twin Turbo C3 build
Impressive work bud. I am glad you don't live anywhere near me. When I started stripping my 72 down 9 months ago I wanted exactly what you are doing. Unfortunately I realized my abilities were not worthy of a custom turbo job. Hope your build becomes more than you expected!
corvettedave383 (12-12-2018)
Update - still been busy working on vette
custom 30 mm alloy bar made into spacer for gearbox tail mount
water canister for cooling system and added a -8an to my dewitts rad - so canister has the pressure cap now and steam line from engine goes in there - see pics
extra breathers for both valve covers, going into catch cans - see pic
started on installing holley efi harness
amandico82 (02-28-2021)
The following 2 users liked this post by corvettedave383:
amandico82 (02-28-2021),
zwede (02-25-2019)
That looks nasty! Did you upgrade the suspension? reason I ask is these c3 get a little scary above 110mph, that car is going to be a rocket, the newer vettes can handle those speeds with ease but not our c3s unless you upgrade. Good luck
full roll cage, including tubes going into engine bay, full qa1 front coil overs and qa1 rear shocks, with 500lb com spring, rack pinion steering, so should be all good
The following 2 users liked this post by DblTrbl:
corvettedave383 (02-27-2019),
sirleo (09-07-2021)
corvettedave383 (03-03-2019)
PainfullySlow (05-07-2019)
corvettedave383 (05-07-2019)
#35
congratulations! Quite the project and it sounds like a beast!
#36
+1 on more pics
#38
Dementer sole survivor
Received 6,247 Likes
2016 C3 of Year Finalist
Very cool
corvettedave383 (05-08-2019)
#40
At certain times of the day, they do switch some lanes of traffic to drive on the opposite side of the highway.
I guess it helps traffic flow, but the first couple of times I was there, it was weird.
They do the same thing in Vancouver, Canada.
