VB&P rear sway bar link bushings
Have VB&P front and rear sway bars from like 2005. Went to replace original poly end link bushings and found that the OD of the nipple that fits through hole in brackets/bars is smaller than the commonly available aftermarket replacement bushings. I've looked at ES and Prothane so far and most vendors don't give specs so I can match to mine. Does anyone know a source for poly bushings that will work with VB&P bars? Thanks!
Give the folks at Vansteel a call, I suspect they will have exactly what you need. 800-418-5397
Good luck... GUSTO
Good luck... GUSTO
