My custom heads were supposed to come with gaskets but did not, and now as im trying to finish up installing the engine i need your help locating some gaskets that are hopefully common enough to be shelf items.
The gasket ID needs to be larger than 1.48 x 1.71 rectangle.
The closest match i can get to these are oval gaskets that are 1.50 x 1.75.
Why doesnt felpro offer a choice off looking up gaskets by application OR port type/size...
I take it you already did the Summit Racing search feature under the "gaskets>header" category? One of the pull down windows on the left of the page has multiple port sizes & shapes.
yes sir, most anything that was close was in Stahl pattern =/
get the white mr. Gasket header gaskets that are hanging on the wall in every auto parts store in the country and trim the inside opening a little bigger if you have to.
yeah i found the oval zz4 ones, ima give those a try, they are close, just a hair smaller, if i have to I'll try whittling them out
