brake pedal hard, then soft - CorvetteForum - Chevrolet Corvette Forum Discussion
Old 12-07-2018, 08:13 AM
autoalain
CF Senior Member
Default brake pedal hard, then soft
Folks, pedal on my 71 is rite at the top after caliper rebuild and new master, adjusted rod also, then start car and it goes down 1/2 way, just to be sure I bleed brakes
again with the special tool that sucks the oil, start car and pedal goes dowm, this does not make sense to me, i'm an old fart and must have missed something, it
is power brakes and good vacume 18 lbs on engine, pls help...Thanks Mike.
autoalain is offline
Old 12-07-2018, 10:06 AM
The Punisher
CF Senior Member
The Punisher's Avatar
Did you bench bleed the master cylinder ?
The Punisher is offline
Old 12-07-2018, 10:40 AM
69autoXr
CF Senior Member
69autoXr's Avatar
Sounds like normally functioning power brakes to me. Did you drive it?
69autoXr is offline
Old 12-07-2018, 11:20 AM
carriljc
CF Senior Member
carriljc's Avatar
Get a pressure bleeder. Or make a pressure bleeder... depending on how much of a hurry you are in.
https://www.corvetteforum.com/forums...y-version.html
carriljc is offline
Old 12-07-2018, 11:31 AM
cardo0
CF Senior Member
cardo0's Avatar
Yes you need to bench bleed the m/c at horizontal - no angle. It should have been in your instructions with the m/c.
cardo0 is offline
Old 12-07-2018, 12:06 PM
MelWff
CF Senior Member
MelWff's Avatar
in addition to the previous comments about bleeding the master, what sequence did you use to bleed the brakes and did you use anything to tap the calipers while bleeding to dislodge air bubbles?
MelWff is offline
Old 12-07-2018, 01:01 PM
autoalain
CF Senior Member
Yep bleed master on desk, started bleeding at r/h rear, jacked car up high at front, used proper tool that sucks from caliper, have NOT tried on the road yet, pedal is rite
at top when car not running, do not think air, rebuilt master also. Thanks
Old 12-07-2018, 06:31 PM
MelWff
CF Senior Member
MelWff's Avatar
why did you jack the car up high in the car should be level, rear calipers have two bleed screws each, rr, lr, rf, lf is the sequence. Have always gravity bled and have never had a problem.
MelWff is offline
Old 12-07-2018, 07:17 PM
HeadsU.P.
CF Senior Member
HeadsU.P.'s Avatar
I disagree on the horizontal. The nose of the MC should pointed up for a few strokes while the MC is in bench vise. Then a few strokes with the nose down, then several strokes at level.
Without tilting the MC around is exactly why bubbles get trapped in bore of the MC. This is why it seldom bleeds & works well on a level car. That trapped bubble is also why pressure bleeders are so successful at removal of the last bubble.
HeadsU.P. is offline
Old 12-07-2018, 07:33 PM
cagotzmann
CF Senior Member
cagotzmann's Avatar
You will get info on bench bleed the master cylinder , but will you let you know you can do this on the car also.
Read this.
https://www.corvetteforum.com/forums...-cylinder.html
Bench Bleeding is a good start to shorten the time for on car bleeding, but on car bleeding will insure you get all the air out of the MC.
cagotzmann is offline
Old 12-07-2018, 08:47 PM
Big2Bird
CF Senior Member
Big2Bird's Avatar
I use the Motive pressure bleeder. Fast, visual, and once you see all the doo doo you can flush out, you will never do it any other way.
Big2Bird is offline
Old 12-07-2018, 10:53 PM
stumpshot
CF Senior Member
Yep! Sounds like it to me too.
stumpshot is offline
Sponsored Ads
Vendor Directory
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
