C 3 Oil pan clearance in an LS conversion
Cruising
1 Post
C 3 LS conversion QuestionsHello every body, I'am in the process of an LS conversion,and found out that the conversion is not easy.
While doing some online research i found out that an LS Oil pan, would not clear the stock Rack and pinion unit, on a C3 Corvette.
When viewing the Corvette Forums, one Member said his Oil Pan would not work and he was going to used the Steeroid Rack & Pinion Unit to solve the problem.
Now I was not planing on replacing my Stock Rack & pinion Unit,but if that upgrade would solve the Oil pan clearance.
I would end up with an Upgraded Rack & Pinion,while keeping the Original LS Oil Pan.
One of my concerns is, if the Steeroid Rack & Pinion Unit,is for my Car with Power Steering,or only for Cars with manual Steering.
My question is has anyone ever done the Steeroid Rack & Pinion upgrade to resolve the LS Oil Pan clearance problem?
Thanks for any Input
Received 1,469 Likes
Cruise-In II Veteran
FWIW: no C3s had rack and pinion steering. If you have rack and pinion, it was added by a previous owner.
Cruising
1 Post
Maybe I should had said Power Steering Unit,instead of Rack and Pinion,and there is always room for learning something that i did not know, but the Problem is still there.Thanks for your input.
Borgeson
Not using the power steering ram on mine as I went to the Borgeson steering box but yeah based on what I've seen with the oil pan on my engine and where the steering ram goes there would be interference. However with the Borgeson there's plenty of room since you don't use the ram.
hey there, very easy to answer
ive got the steeriods power rack and pinion system on my car, ive installed a lsx/ls3 engine, using a holley oil pan and ive got tons of room and engine is set in its lowest possible mounting position aswell
have a look at the thread below, has a picture of my oil pan and steeriods rack, loads of room and other good info concerning LS swap and link to the exact oil pan ive used
https://www.corvetteforum.com/forums...-mounts-2.html
https://www.holley.com/products/acce...ns/parts/302-3
Cruising
1 Post
I want to thank all of you guys for your input.
The Engine that i have is a LS 3, 6.2, out of a 2008 Corvette .It.s the one that's rated at 430 HP.
The car that I'm putting it into is a 73 Corvette,with a TKO 600 5 speed.
Is the Borgeson steering box a Power steering unit ,or a manual steering unit?.
I just got the Motor 2 days ago,and right now I'm waiting on my Flywheel and Clutch and Pressure Plate.
Also i seen in a forum that because the Crankshaft on an LS Engine, is a little shorter than the older small
block GM Engine, and require an after market Pilot Bearing,to protect the output Shaft of the Transmission.
Once again thank you guys for your Inputs
I have an 09 LS3 from a Corvette. I had Steeroids in mine and it fit but just barely. The bellows of the Steeroids was rubbing the pan. For other reasons than this I switched over to the Borgeso unit. Clearance is no longer an issue at all. The Borgeson unit is a power unit also.
Cruising
1 Post
Thanks for the input. i will look at the Borgeso unit.That's was what i wanted to know.
So what I'm going to do, instead of putting x amount of money into an after market Oil Pan,
just put the money into an Upgraded Steering.Thank you Gordonm
Gordonm (12-10-2018)
Got mine from VanSteel in Tampa, as well as other parts. Give them a call and they can give you some advice on what to do..
You should be able to keep the stock steering setup if you wanted. I have a crate ls3. Switched the pan out to an fbody pan and done. I left the stock power steering setup. Good luck.
FYI. As you may know, LS engines have oil starvation issues when cornered hard, which is why late model vettes come with dry sump systems. If you are replacing or removing your pan, Improved Racing makes effective baffle kits that bolt into various stock GM pans.
Rick
Rick
corvettedave383 (12-16-2018)
Rick
Rick
http://www.improvedracing.com/oil-pa...pan-p-441.html
Rick
Rick
That's a great tip. I have an F body pan that I'm going to use with my LS2 swap and have already picked up the Improved Racing baffle.
It looks like a very nice piece and has a couple of trap doors, similar to a road race pan.
I can't wait to get this motor swapped in and get back out there for another season of autocross.
Also, FWIW I had used another parts car and mocked up the motor/trans with the F-body pan and it fit great.
Take Care,
Chris
