c3 water pump
tonyg1097 (12-22-2018)
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,925 Likes
I have always removed the fan first, because "that's the way it's done." But the nuts attaching the fan and pulley to the pump shaft are a pain to get to when you're reaching over the C3 fender. The 4 bolts attaching the pump to the block are easy to get to whether the pulley & fan are attached or not. The fan will easily come out of the shroud while attached to the water pump. So why not disconnect the hoses, unbolt the pump from the block, and pull the entire pump/pulley/fan assembly out as a unit, and then remove the fan & pulley on the workbench in comfort..? I think it's a brilliant idea, and I'm going to try it the next time I do a water pump on a C2/C3!
Lars
Actually I think the OP has a damned good idea...
Lars
Lars
Lars
Don't try that on a stock 81-82 my lad.
Lars
Now I really gotta try it. I don't have access to an 81/82, but I do have access to a couple of '79s. I'll post the results when I do it...
Lars
Lars
Between the fan/shroud/fan clutch,brackets, etc.......you'll see. Beer?
Just for fun, jamb a spreader bar right in front of the pump sheave. (I know, not stock).
You might be able to get away with calling me "brother." But it would have to be from a different mother...
Little brother?
