Bearing material in pan, what would you do?
Old 12-30-2018, 04:03 PM
randallsteel
Junior Member
Default Bearing material in pan, what would you do?
hey guys,
i have a 1975 L48 corvette. It has 108k miles on it. I drove it yesterday and it ran great. I took the oil pan off today due to the pan gasket leaking. I found some strips of bearing material in the pan. There are 4 strips, all of them about 1/2 inch long by 1/4 inch wide. The material is easily bendable. I grabbed and shook each connecting rod and the only one I was able to get movement out of was #5. I could slide it back and forth a little. My question is what would you do if this was your Vette? It makes no knocking noise when it was running, I would have never guessed that there was some bearing damage. Iím thinking about putting the pan back on and driving it while saving some cash for a new bottom end. How long do you think the bottom end will last? I have rebuilt engines but Iíve honestly never had an engine start to go bad on me. No experience with how quickly things will go south.
On another note, I was surprised to find out I have a 4bolt main, I thought L48s came with a 2 bolt main?
thanks, Randall
randallsteel is offline
Old 12-30-2018, 04:13 PM
Big2Bird
CF Senior Member
Big2Bird's Avatar
Quit while ahead. Cheaper now. If you have a clutch, might be thrust surface from rear main.
Big2Bird is offline
Old 12-30-2018, 04:14 PM
Vette5311
CF Senior Member
Vette5311's Avatar
Default Stop now........
The only thing that can happen with more miles is more damage. May mean the difference between being able to turn the crank or having to replace it. Or you could ruin a rod and crank and then add rebalance to the bill. Nothing good is going to happen. Never seen an engine heal itself.
Vette5311 is offline
Old 12-30-2018, 04:41 PM
HeadsU.P.
CF Senior Member
HeadsU.P.'s Avatar
Something tells me that that's not bearing material. But I don't know what it is.
If it were mine, I would start at the front of the crank and pull off a rod cap, inspect, reinstall, torque to specs, go to the next one. Write down which number cyl if you find something.
Also, run a magnet around the bottom of your pan. Any glitter? If there was truly wear & tear, there should be glitter.
Trying to think what would be 1/2" long X 1/4" wide. metal strip.
HeadsU.P. is offline
Old 12-30-2018, 04:43 PM
Big2Bird
CF Senior Member
Big2Bird's Avatar
Picture is worth......
Big2Bird is offline
Old 12-30-2018, 04:46 PM
jackson
CF Senior Member
Sorry for you R
I agree with all the above.
Pull rear main cap & rod cap#5 ... find the culprit ... make certain you know where each cap came from ... keep pulling caps 'til you convince yourself it's time to make some sort of change.
jackson is offline
REELAV8R
CF Senior Member
REELAV8R's Avatar
I would remove all the con rods and mains to inspect the bearings. If any of them is damaged/ missing chunks I would just replace them all. It will also give you a chance to inspect the mating surfaces for damage.
REELAV8R is offline
Old 12-30-2018, 04:47 PM
fparkin
CF Member
fparkin's Avatar
I agree we need photos to see what happen
fparkin is offline
Old 12-30-2018, 05:03 PM
thatcorvetteguy
CF Senior Member
thatcorvetteguy's Avatar
Sounds to me like a thrust bearing.
thatcorvetteguy is offline
Old 12-30-2018, 05:12 PM
randallsteel
Junior Member
Old 12-30-2018, 05:16 PM
randallsteel
Junior Member
Thanks for the all the thoughts. I’m not a master engine builder nor do I have tons and tons of experience, but I thought that if the material is pliable and bendable then it’s bearing. I’ll take yalls advice and start pulling rod caps tomorrow and see how they look.
Old 12-30-2018, 05:29 PM
Anton Chigurh
CF Senior Member
Location: What's the most you've ever lost on a coin toss?
another vote for thrust bearing
Anton Chigurh is offline
Old 12-30-2018, 05:36 PM
Big2Bird
CF Senior Member
Big2Bird's Avatar
Does the car have a clutch?
Big2Bird is offline
Old 12-30-2018, 05:45 PM
randallsteel
Junior Member
It’s an auto, TH-400
Old 12-30-2018, 05:48 PM
Big2Bird
CF Senior Member
Big2Bird's Avatar
Just keep looking for where it came from.
Big2Bird is offline
Old 12-30-2018, 06:02 PM
derekderek
CF Senior Member
Replace all 8 rod bearings. Pull the main caps and check all 5 mains. If lower main shell is good, upper will be too. Post pics of any crankshaft damage.
derekderek is online now
Old 12-30-2018, 06:45 PM
Fredtoo
CF Senior Member
Originally Posted by randallsteel View Post
hey guys,
thanks, Randall
Back and forth in which direction?
Front of car to back of car might be OK, Right wheel to Left Wheel is a big problem,
Fredtoo is offline
Old 12-30-2018, 06:58 PM
HeadsU.P.
CF Senior Member
HeadsU.P.'s Avatar
At this point you and other posters are speculating bearing material. No parts have been removed to verify anything just yet. Your original post could have stated:
Metal material in oil pan. Any ideas?
If that material in the photo was from a bearing, I think you would have heard something. Something awful.
Old 12-30-2018, 07:46 PM
randallsteel
Junior Member
Heads UP, that is how I feel as well. I was very surprised to find metal in the pan because I had no indication that anything was wrong. I just assumed it was bearing material because it’s soft/pliable and non magnetic. I’m going to remove some caps and check tomorrow, but if everything looks good I wonder where that metal came from.
Old 12-30-2018, 08:32 PM
derekderek
CF Senior Member
Check them all.
Quick Reply: Bearing material in pan, what would you do?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
