A Borgeson question I've not seen asked
#41
I've gotten rid of the stock PS in two Vettes.
In my 80, I swapped over to stock-style manual steering, with the proper drag-link and pitman arm. I have a GTR1999 steering box ready to install this winter, but even with the old sloppy box, steering is improved, but parking is difficult (backing into spaces, as I do with my truck anyway, helps.)
In my wife's 79, I put in a Borgeson box. She loves it. Steering is light and quick, with no slop. I added a U-joint, the frame brace, and shortly after the install, a newly rebuilt PS pump. I had to pull the column to collapse it.
The number one improvement, however, is that neither system leaks. I was going through a quart or more of PS fluid per month.
#42
Old Pro Solo Guy
In my case I have manual steering now, which I cannot stand with a BB.
So I have to buy something, either the leakprone original slow steering setup or the faster ratio, newer, leak free Borgenson. Costs is about the same, so in my case, it's no contest.
