Edelbrock XT Sequential Port Injection
Old 01-12-2019, 10:38 PM
  #41
zwede
CF Senior Member
zwede's Avatar
Originally Posted by BobRiley View Post
So, do I just need to buy a coil and coil wire to attach to center of cap? No MSD box?
Says it has a built-in driver, so no MSD box is needed.
zwede is offline
Old 01-13-2019, 01:30 PM
  #42
BLUE1972
CF Senior Member
BLUE1972's Avatar
looks cool
BLUE1972 is offline
Old 01-13-2019, 03:00 PM
  #43
BobRiley
CF Member
All done except air cleaner and a fuel line I will finish when parts show up tues.
BobRiley is offline
Old 01-13-2019, 03:06 PM
  #44
DorianC3
CF Senior Member
DorianC3's Avatar
I canít wait
DorianC3 is offline
Old 01-13-2019, 03:23 PM
  #45
Radman2112
CF Member
Radman2112's Avatar
Looks great. So, you use the distributor that comes with the kit and you need to use a coil,no HEI, right? What or how do you hook up the tach? Is there a connector in the harness? What are you going to do about a cold air intake? Thanks.
Radman2112 is offline
Old 01-13-2019, 03:46 PM
  #46
BobRiley
CF Member
Yes, used the dist that came with kit. Bought coil, coil bracket, and single coil wire. Pcm has two wires for direct connect to coil. It has a rpm output signal wire for tach.
Another cool option that i didnít use- or havenít decided to yet- it has two coolant fan output wires( read that as 2 separate fan controls) and a fuel pump signal wire. Since all these were low voltage and required external relays and I already had electric pump and fans all wired in, I chose to not use this signals for now.
I am going to use a 90 degree silicon hose off intake manifold to hard pipe to air filter on passenger side above swing arm. I have large filters and pipes here we use to fabricate diesel intakes, so this will be pretty simple. I just need the 90. I can squeeze a 4Ē on it, but itís really a 4.25Ē which is hard to find as a 4.25 x4Ē 90
BobRiley is offline
Old 01-13-2019, 03:54 PM
  #47
BobRiley
CF Member
Also, you have to install an O2 sensor. They give you a weld on bung, but I This was way easier. I ordered this before I even started.
BobRiley is offline
Old 01-13-2019, 05:12 PM
  #48
Jebbysan
CF Senior Member
Jebbysan's Avatar
Would you care to explain the fuel system on this....? It looks as though you have a external fuel pump, filter and reg all on the intake......so you are feeding the system from the stock fuel line to here? Pretty freakin easy looks like......
Jebby
Jebbysan is online now
Old 01-13-2019, 05:26 PM
  #49
BobRiley
CF Member
I understand some c3s donít have return lines factory, but my 76 did. So, yes, I just ran the supply and return back to oe lines simple. Hereís a couple pics to help. What you donít see is the braided fuel line from fuel filter to reg, and from reg to rail. Those are the parts I will have tues to finish.
BobRiley is offline
Old 01-13-2019, 05:28 PM
  #50
Jebbysan
CF Senior Member
Jebbysan's Avatar
That is crazy simple.
I wonder how big of a cam this system supports?
Jebby
Old 01-13-2019, 05:29 PM
  #51
BobRiley
CF Member
The air temp sensor has to installed in the intake as well
BobRiley is offline
Old 01-13-2019, 05:32 PM
  #52
BobRiley
CF Member
I just thought of something. I have a serpentine kit which cuts the ac compressor real estate into nothing compared to oe. The air intake might be more difficult if you left the stock style v-belt system on, but I canít show that.
BobRiley is offline
Old 01-13-2019, 07:47 PM
  #53
zwede
CF Senior Member
zwede's Avatar
Curious to see how that fuel pump will work for you. I've always heard an electric pump has to be mounted below fuel level or it will burn out trying to suck air. Does Edelbrock list that mounting location for the pump as an option?
zwede is offline
Old 01-13-2019, 07:59 PM
  #54
BobRiley
CF Member
no, but this is our pump we made for the trucks. I know how high it will pull and my supply line on the top of the frame will constantly dump fuel from siphoning, so while Iím aware itís higher than the tank, itís not much and Iíve sucked fuel higher then this with this pump, so if it craps put, Iíll move it.
BobRiley is offline
Old 01-14-2019, 07:29 PM
  #55
BobRiley
CF Member
How do I post a short video?
BobRiley is offline
Old 01-14-2019, 07:41 PM
  #56
zwede
CF Senior Member
zwede's Avatar
Upload it on youtube and then put the video ID inside yt brackets.
So a video with this URL: https://www.youtube.com/watch?v=1234567890
You'd put this (remove space before yt) : [ yt]1234567890[/yt]
zwede is offline
Old 01-15-2019, 03:51 PM
  #57
ZEN357
CF Senior Member
ZEN357's Avatar
Love the look of it on the older Corvette!!!
ZEN357 is offline
Old 01-15-2019, 04:15 PM
  #58
DorianC3
CF Senior Member
DorianC3's Avatar
Absolutely [email protected] on an older corvette
DorianC3 is offline
Old 01-15-2019, 05:04 PM
  #59
BobRiley
CF Member
BobRiley is offline
Old 01-15-2019, 05:16 PM
  #60
DorianC3
CF Senior Member
DorianC3's Avatar
[email protected] Want. #BlueWithEnvy
DorianC3 is offline
Quick Reply: Edelbrock XT Sequential Port Injection
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
