Coolant out to heater core
All,
If I remember correctly, my heater hose came off of the top of my intake when I took everything apart.
I noticed that my new aluminum water pump has a 1/2" npt fitting that I can attach a hose barb to - does it matter if I attach the heater core hose to the intake or to the water pump?
(I'm thinking that there would be more flow / pressure if I attach it directly to the water pump output....)
Thoughts?
Adam
Thoughts?
Adam
The intake is the supply.
The water pump is the return.
Adam,
As stated there is a feed and return hose on the heater core so you need to hook up to both the water pump and intake. The hoses are also different sizes. 5/8” hose on the intake and 3/4” on the water pump. Here are the fittings I used:
https://www.summitracing.com/parts/prs-1009
I know this has been discussed before but is there any valid reason why those fittings cannot just be capped off? I don't want to accidentally turn the heater on and flood the floorboard with coolant from a 40 year old heater core.
yes they can be capped off. You could also just put a loop hose on from one to the other. You could also put shut-off valves in both hoses so you can turn them on if you want heat and then turn them back off when you don't.
There are many stationary engines with pipe plugs in them. Boats, generators,pumps,etc.
Thanks all. I knew it was a loop; I just assumed that the output would be coming from the pump for better pressure.
My intake doesn't have a great place for the output currently.... (I have the stock temp gauge in one intake 1/2" NPT port, and my new digital one for my Holley HP EFI, and the 3rd port in my intake is partially blocked by the high flow Mr Gasket thermostat that I have (It's way thicker than normal)...
Adam
Adam
Adam,
Not sure if your Jegs heads came with the 3/8NPT port between cyclinders 1&3 like my profilers did, but I made a pilot drill out of an old drill bit and drilled it out and tapped it for 1/2NPT to use the stock location/sending unit on my 79. I got a couple quotes from shops for $40-50 so that might also be an option for you too if the heads are still off the engine. Good luck.
