68 fuel tank replacement
Another thing you might think about is ordering a new cork filler neck gasket as they dry out, crack and leak. When installing the tank it is easier to rotate it into place with the filler neck removed and some masking tape over the opening. Once it's in place, rip off the tape and install the neck. Most vendors also have the whole tank kit that includes everything including new sender, sock, seals and hoses. A bit cheaper that way. That's what I did on my 69.
i can’t get the picture to load but it’s the unit itself then one cork looking gasket and another black gasket. Is that what you are referring to?
Yes. Gas fill neck cork gasket. I think it's included in the kit from Corvette Central. You get everything including new straps and pads, sender, sock and gaskets and the whole thing goes for around 300 bucks. I think the only other thing you need is the connector hose or hoses. Can't remember if they come with it. I did mine only removing one muffler (right side) instead of both but both would be a bit easier. It was actually a fun job and the tank sticker was still there!
$300 for everything is not bad at all. Sourced individually its about 160 for tank + 40-80 for the sender and $50 for the install kit with all the straps etc. Thanks for that, i'll check it out.
* just saw the kit for 309 on corvette central and 229 on corvette America as well as corvette mods....is there something im missing here? I don't see why one vendor is $80 more.
