Temps and stat
Old Jan 16, 2019 | 06:00 PM
BobRiley's Avatar
BobRiley
Default Temps and stat
What stat are you running and what temps are you running?
Old Jan 16, 2019 | 06:45 PM
HeadsU.P.'s Avatar
HeadsU.P.
T180 & 185*
Old Jan 16, 2019 | 06:47 PM
BobRiley's Avatar
BobRiley
192 and idling It gets to 210 to 212 pretty easy
Old Jan 16, 2019 | 06:51 PM
HeadsU.P.'s Avatar
HeadsU.P.
That's acceptable to most. I start to worry above 200* at highway speed in July however.
Remember:
Overheating at speed is a Water circulation issue.
Overheating at idle is a Air circulation issue.
Old Jan 17, 2019 | 10:01 AM
gkull's Avatar
gkull
Originally Posted by HeadsU.P.
Remember:
I don't believe in blanket statements. Your air at idle is correct, but water at speed. No at speed is a relationship of frontal square inches vs the ability to remove the heated air from behind the radiator
the chin spoiler on the front channels higher pressure ram air through the radiator and creates a lower pressure behind the radiator causing air flow. Increasing the size of the chin spoiler and bringing it closer to the ground increases the low pressure behind the radiator.
I use a big aluminum radiator and have tried different aluminum water pumps and pulley diameters. Doubling the gallon per minute doesn't double the cooling
I've also played with decreased frontal Sq. Inches needed to cool at terrific high speeds at long distance sustained open road racing. Just look at a modern Vette front end
Old Jan 17, 2019 | 11:33 AM
HeadsU.P.'s Avatar
HeadsU.P.
Its a broad statement that reflects 90% of overheating issues. It makes sense. If the vehicle is traveling at 50, 60, 70, mph then its getting plenty of air circulation.
So that leaves IGN timing, or that leaves water circulation issues. Inside clogged Rad, water jacket issues, thermostat, missing spring in lower Rad hose, waterpump, etc.
Overheating at stand still or idling, there is little to no air forced through the Rad. But most likely the waterpump can keep up. So investigation would include air circulation items: fan, clutch fan, fan belt, outside blocked radiator, missing Rad foam seals, missing shroud, etc.
Old Jan 17, 2019 | 11:58 AM
JoeMinnesota's Avatar
JoeMinnesota
I run a 160 thermostat in my 355 and it runs very cool ... maybe too cool ... may change to 180 in the spring when it comes out.
Old Jan 17, 2019 | 12:13 PM
spinadog's Avatar
spinadog
I had this problem and a hi-flow thermostat (moroso?) completely eradicated the issue. I also drilled the 1/8" hole to prevent air pockets - also a huge success. 468 with a Dewitt radiator (awesome) with all seals, dams, and shrouds in place to spec, rebuilt standard clutch fan. I cannot recall the T-stat rating but I get to 195 and never seem to vary, no matter the ambient temperature or speed.
Old Jan 19, 2019 | 06:04 PM
Street Rat's Avatar
Street Rat
180 thermostat in my 355. Runs at 180 all day.
Old Jan 19, 2019 | 07:23 PM
drwet's Avatar
drwet
427 small block. 180 stat. Runs at 180-190 degrees
Old Jan 19, 2019 | 08:43 PM
BobRiley's Avatar
BobRiley
Originally Posted by Street Rat
195 thermostat in my 355. Runs at 180 all day.
that id love to hear how this is possible. 195 stat would mean you have no radiator flow. I assume someone drilled a hole in the main plate to bypass the stat.
Old Jan 19, 2019 | 08:57 PM
lars's Avatar
lars
Always keep in mind that the thermostat can only control the minimum temperature of the engine. The thermostat has no control at all over maximum temperature of the engine. If you're having overheating problems, you won't solve it with a thermostat temperature range change, unless the thermostat is defective.
Lars
Old Jan 19, 2019 | 09:59 PM
BobRiley's Avatar
BobRiley
Lars
exactly why I asked how it was possible. A 195 stat mandates 195 and no less. It has no control over the engine getting to 250, but it certainly makes sure the minimum operating temps are no less that it’s opening temp.
Old Jan 19, 2019 | 10:07 PM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Lars
It sure does! You just need a radiator of adequate capacity for the TS to do its job of maintaining optimal engine coolant temp. Then the engine will run all day long within a few degrees of the TS rating.
Old Jan 19, 2019 | 10:51 PM
lars's Avatar
lars
No. The 'stat cannot control max temp. Only minimum temp. Once the thermostat is open, it's open, and it cannot do anything more. Max temp is controlled by cooling system capacity, heat load into the system, and heat exchange efficiencies.
Lars
Old Jan 19, 2019 | 11:18 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Lars
This is true....there is no possible way a thermostat can control what temp an engine is running after that thermostat is open all the way....it is not functioning at that point to control temp in any way....
A 195 degree thermostat installed in an optimized cooling system will run 195 degrees.....
if the cooling system is inadequate, it will blow past 195 and keep climbing.....
Thermostats control the minimum operating temperature, not the maximum.
Jebby
Old Jan 20, 2019 | 12:26 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Let me put it this way....
If your Vette runs 230 degrees with a 195 thermostat
it will run 230 degrees with a 180 or 160 thermostat as well.....it just will.
If your Vette runs a steady 180 with a 180 stat....you Might run cooler with a 160....if the cooling system is that efficient enough.
Jebby
To Temps and stat
Old Jan 20, 2019 | 08:59 AM
Street Rat's Avatar
Street Rat
Ha Ha.
Yes Sir I'll correct my post.
Old Jan 20, 2019 | 10:30 AM
mrvette's Avatar
mrvette
Jebby
THE REASON for that is.....a few decades ago, a 160-180 stat had a larger passage hole, today they all the same as a 195 stat, so they restrict the flow rate, old cars still need the higher flow rate to meet the designs of the OEM stuff.....only way to do that is drill about 3-4 3/16 holes in the skirt of the stat, OR just cut the skirt of the stat to allow more water around the stat, that will slow the heating a good bit in cold weather, and if you driving in way below freezing, it may not allow engine to warm up nicely.....BUT here in Florida with the opened stat setup, I can do the freeway and get off in 100f back yard ambient, but know damn well that black assfault main commercial highway full of stop/go traffic has air temp beyond blistering....yet the engine is fine....
Old Jan 20, 2019 | 11:09 AM
JoeMinnesota
So, what running temp is too LOW in your opinions? I'm thinking change up to 180 stat to bring my temp up, as my combo is running down at 160 with the 160 thermostat. Is that sufficient for good combustion? In the spring and fall it doesn't give much for heat in the cockpit.
