What head for 383 builds
Wallace says. 4.030 bore X 3.75 stroke at 5500 rpm needs a 1.93 minimum cross section to not choke. AFRs 180 head has a 1.810 minimum, there 195 head shows 1.905 minimum.
I was told that with a mild cammed 383, less than .500 lift and under 5,500 RPM limit, AFR 180. Anything over .500 Lift and over 5,500+ RPM redline (6,000 RPM + really), AFR 195 as a very broad guide....by my expert builder when I built my L-82 355..................I asked for Sh*ts and giggles if I decided to scrap the L-82 forged crank and go 383, which I did not, based on his advice for what I wanted....best decision ever.....
NewbVetteGuy (01-22-2019)
Mamo that came on speed talk offten and made current eliminator AFR cylinder heads highly recomended 195 heads on any 383 and recomended further the race version of it. Makes zero difference to me what head anybody uses, but then what would the guy that actually made and extensivly tested them know !!!
The math doesn't lie, go with the calculator.
you need half the displacement in port volume as a general rule of thumb. BUT, that is to get max power at full throttle. if you are not taking it to the drag strip, a bone stock small valve head will run well. they put those little round ports on 454's and the trucks run good forever. actually improves 1500 to 4000 power. I have little round port heads. they sit in the garage as spares for the big slow boat. once I get a big block in the vette, it is gonna have rectangle port heads even though they are too big on paper until 6000 or so.
Neither choice is wrong.........
.......build the engine for what you want it to do. Torque (on the street) bottom end go for velocity with the smaller port (with a cam to match). Want your HP at higher rpms then let er breathe with bigger ports. Again with a cam to match. Don't try to straddle the fence.
kind of what I was saying. we are not driving 40 miles to work thus needing to optimize fuel mileage at 2200 rpm. and unless we are trying to get a small block into the 10's optimizing port size for 6500 rpm is also not a big priority. it is what you want it to be. and 195 works good for 383's. don't go to much cam, but you don't want it to idle like an Impala either...
the sad part back then is that I didn't have lots of disposable income to buy up a bunch of different head models like 195, 220, 235, and 245
Received 1,874 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
There's a LOT to a head other than just port cc's. It's 'where" those cc's are within the port that make a difference. The 180's would be a choice for a mild 350......the 195's are definitely not a problem for a milder 383 etc. They are just good solid heads that will make power and drive well.
Heck....I did a 388" for a buddy in a '65. He's got a wide ratio and 3.36's. The thing will idle away from a red light literally with almost no throttle....and it's got 215cc heads and a single plane intake.
JIM
JIM
The following 2 users liked this post by 427Hotrod:
Jebbysan (01-21-2019),
Metalhead140 (01-28-2019)
Dr. Detroit
Received 3,891 Likes
Math does not count for any venturi effect....or velocity relative to piston position.
Without getting into a bunch of ***** that nobody understands.......go with the 195 AFR or 200 Dart Pro 1 Platinum.
Jebby
Also AFR are about the best you can get without going exotic and or custom ported. Of course the Brodix people will argue. Patriot and pro comp people...they argue how much they saved.
Guys,
Maybe I can help here.....there is no one head fits all.
The correct head choice is application sensitive always (and to some extent who's azz is in the seat and how they typically drive their vehicles).
The following is a general type of statement but also fairly representative and I will focus on the AFR line up of head because as their designer Im a bit partial to them.....LOL
A 195 is hard to beat for a solid all around street engine with a mild or moderately sized HR cam.....more aimed at the conservative driver that spends most of his time under 6000 RPM
A 210 is a good choice for a hotter street strip application.....slightly larger cam and more RPM.....the guy that wants to run it up a bit and spin it 65-6800 RPM when he races it. Still a great choice with a conservative cam if your looking for a head you can get more aggressive with later.
Next would be either a AFR 220 or an AFR 227.....this is the best choice if your building more of a strip/street application.....a Friday night bullet kind of application and best suited to an SR cam that will allow 7-7500 RPMs. You can make big power with the right set-up here but naturally your lower end power will suffer and its more heading towards a race build than a street build although still easily street driven given a manual trans or a stalled auto with (potentially) some aftermarket rear gears in the mix.
I can help design an entire package for the OP or anyone else reading this and supply the cylinder heads spec'ed with the correct springs and chamber volume etc., custom cam, ported intake manifold.....carb.....valvetrain etc.
Please feel free to reach out to me if I can be of assistance. Naturally Mamo Motorsports is a dealer for AFR products and I can be very competitive with my pricing etc.
Hope some of you guys found this post informative
Regards,
Tony
Regards,
Tony
__________________
Please take the time to also visit my website at www.MamoMotorsports.com
The following 2 users liked this post by Tony @ Mamo Motorsports:
Metalhead140 (01-28-2019),
Thanks for your time and help to others mr mamo. Im bumbed that the owner of speed talk has died. Can olny hope his wife will try to run it or sell the rights to someone else. i love vettes will always look at this forum but the amount of knowledge that came on speed talk was unreal.
I have a good feeling that his wife and family will do whatever they need to in an effort to keep that forum active.....its a part of his legacy.
Spoke with him on the phone a few times but didn't really know him
Very sad....my condolences to his family and friends
Sincerely
Tony
Received 3,043 Likes
St. Jude Donor '05
DItto, that site can be humbling with all the brains on there, I bet it stays up. The information there trumps about any enthusiast forum around.
Good to see you drop in Tony. Those Darts you did years ago are still rockin.
Something quick like that very hard on a family unexpected no time to except its coming. Ya about a month ago i noticed at the top of engine tech it said... Read only while i fix a database problem. Been stuck on that page at least a month. Found out another way that the owner had passed. There many on this forum above my pay grade but speed talk its people from nascar to pro stock come on it. John kasse 13 time ahra engine bulider champion darion morgan another pro stock engine builder. People that make camshafts. Machinest even a guy with bonneville record old triumph.
