LSx run in oil?
Dr. Detroit
Received 3,892 Likes
You can’t seat rings with synthetic oil.
Sorry for the confusion.....
Jebby
There is a lot of myths and speculation out there and I am no expert or engineer as there are a lot smarter engineers at GM that design this but if the block is machined correctly the rings will seat with either type of oil.
Open for discussion
ignatz (02-01-2019)
Received 1,126 Likes
Looking into this a little deeper this is an ongoing debate on most forums. Most of the top engine builders state now with the machining tolerances now that can be held with modern equipment there is no need to "break in" the motors. Rings included. From all that I have seen and read all the GM LS engines come with synthetic oil from the first fire of the spark plugs.
Open for discussion
Open for discussion
Gordonm (02-01-2019)
Yes Correct my LS7 Z06 came with Mobil 1 5-30 synthetic from the factory as well, BUT all GM engines and cars come with a detailed breakin procedure regardless of the factory oil fill. I think that the tolerances are MUCH tighter on new generation engines which as surmised allows for synthetic oil to be used during breakin versus conventional oil for breakin on my Gen 1 355 L-82 after its rebuild. The notion that keeps coming up, though, that newer GM engines, crate motors, roller cammed Gen 1 SBC, or ANY motor when new does not need a breakin, frankly, is a little ridiculous. The fact is that any new motor with new parts will experience metal shavings and filings during the first 1,000 miles or so. Those metal shavings and parts can and will contaminate the new engine internals if not done progressively with subsequent oil/filter changes....There is no getting around this new engine event.
Those who start new engines and let er rip are most likely not going to see the fruits, or lack there off, until later in the engine's life. I mentioned this earlier in another thread, that I am often shocked at the very few thousand miles some of these rebuilt SBC's go before another rebuild is necessary and I am beginning to understand the cause of this event?????!!!
I've had a few LS engines built over the years. First start on a engine dyno with dino oil typically 10-30 race? oil. Then after a short run up to temp both the oil filter and oil are dropped and filled with 10-30 Mobil 1. That is what the engine builder likes so who am I to second guess. All have run well.
Ive searched these forums and others, cant really get an exact answer relating to my question
Ive got a new LSX b15 crate engine from GM, trying find out what run in oil to use - mineral or fully synthetic?
the gm create instructions say to use a fully synthetic oil at break in?
general talk on the web seem to suggest mineral to start with or is that relating to older engines or ??
thoughts?
thoughts?
corvettedave383 (02-02-2019)
Here is non auto engine anecdote.
Brand new lawn tractor with 15 hp Kohler Command Engine in 1998. Kohler says breakin the engine using 10W-30 conventional oil for 25 hours and then change oil/filter. I always warmed the engine to operating temp during the breakin 25 hours before using. I do just that and then switch to 5W-30 Mobil 1, later Mobil 1 15W-50, and for about the last 10 years Mobil 1 0W-40 European Formula, none of which is specified by Kohler as an approved weight OR to use a synthetic, over the intervening 22 years. This engine today has somewhere between 2,500-3,000 hours on it cutting grass and does not burn 1 drop of oil during the cutting season. I change the oil and filter once per year, 2 qts Mobil 1 synthetic, and good to go.
2 points:
This engine required a conventional oil breakin and the synthetic oil has no doubt allowed this engine to operate with zero oil usage after so many hours. The local lawn repair guys are astounded that the engine is still operating and burns zero oil. Hmmmmmmmmm
2 points:
Had a 1976 L-82, 4-sp
Location: Some days your the dog and some days your the hydrant.
Received 1,199 Likes
Royal Canadian Navy
15 hp Kohler Command Engine - you can't kill it! LOL! Had mine for 13 years and only changed the oil twice! Used the JD LT150 in the winter too with a 42" snowblower.
I think engine design technology has progressed to the point where break-in is not required on some engines but is on others. Rings are designed to seat with dino or synthetic oils from first start-up, afaik.
