Does this sound like a decent setup?
Is that a station wagon conversion? You have to show us more pictures now.
I'd be more concerned about not having a manual transmission. The interior looks clean, but why the dash pad?
From what I'm reading that 700R4 trans isn't ideal for high hp/torque applications. Seems the 4L80E is better.
Dr. Detroit
Received 3,892 Likes
4L80E is a great unit but has to have a computer to run it.....hence the "E" in the name.
99% of people who comment about how bad the 700r4 is have never had their TV cable adjusted properly......and for this particular trans....it is EVERYTHING.
Jebby
Received 3,043 Likes
St. Jude Donor '05
ive run big blocks in front of 700rs they all held up but have to be built right and not overheat
One problem is I don't know how competent the shop that did it is or exactly what they did to it. The guy who's selling the Vette says it's supposed to be built for 700 hp, I don't know how he/they arrived at that.
Dr. Detroit
As long as it is a sound build and the TV cable is adjusted right.....it should work well for you assuming a nice big cooler.
Jebby
#34
This is what I consistently find as common wisdom.
It's just aggravating because this car is so straight otherwise and it does run great, if only it weren't a problematic build. I don't know if he cobbled these pieces together out of ignorance because he didn't do enough research or if in his opinion he decided this particular blower isn't potent enough to be a problem.
#36
#38
#39
See
There aren't a lot of pics - all the exterior is going to show you is a primered albeit straight 'Vette. The undercarriage which I don't have any pics of is really the most impressive view currently, it's very clean.
Here's a few that show the engine bay and interior. There's also a front-facing scoop-type air intake, whatever the official name for those are.
#40
