79 L82 code 4 - loose lifters
Hello everyone...
I am replacing my leaking valve covers/gaskets with new ones, while at it I checked the lifters and I have a couple loose should I work on that or just live it alone? What torque should those lifters be at in a complete stock engine?
One more question to I need to sand down the head surface were the gasket makes contact completely to the metal or just make sure the surface is smooth? I used yet sand paper and removed most of the oil/gunk/gasket but it still has some dark spots on it that would require more sanding to be 100% metal...
suggest you acquire your own copy of a basic repair-rebuild manual for small block chevy.
your lifters are NOT adjusted using a torque value.
your lifters ARE adjusted using a LASH method.
suggest do Not use sandpaper on gasket surfaces.
suggest DO use a penknife followed with scotchbrite abrasive pad.
get a book!
get a book!
C3-79 (02-18-2019)
Received 2,124 Likes
Good God NO, sandpaper! Would you take some sand and sprinkle it on the cylinder head? That's exactly what sanding would be like. Where does the sand go? Into the oil. Where does the oil go? Into the bearings.
Use a plastic razor blade (eBay) and a rag soaked in Acetone (Walmart) to remove old RTV / gasket material.
Lifters (rocker-arms) are not torqued to any specifications. They ARE however set and this is called setting the valvelash. Check on YouTube for some videos for SBC valvelash adjustment. A common rachet / socket will do the trick. Do not leave any loose, watch the video.
If some of the rockers-arms are loose, I suspect your camshaft might be suffering abnormal wear. Are you using a oil with Zinc content mixed in?
C3-79 (02-18-2019)
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Setting lifters is not hard, but you do need to know what you are doing. Do not get a general repair manual, i.e. Chilton's, etc. They are garbage. HeadsUP is correct about YouTube
C3-79 (02-18-2019)
Received 3,043 Likes
St. Jude Donor '05
lifters can bleed down some after its shut off making you think its loose when they are really just fine. Once running if they tick a lot could be different.
C3-79 (02-18-2019)
get a book!
get a book!
I did check youtube but my muflers are shot and the cars is really loud... I have to replace the rusted muflers in order to be able to hear the valves while adjusting...
I can't hear the valves over the rusted muflers I will have to replace it before doing that....
