82 tbi 's leaking gas
just purchased 82 vette with 55000 original miles , I have had the chance to take it out a couple of times however in new England not good weather rite now after I park the car in the garage I get an slight odor of gas I believe its comin from the throttle body is this normal for this year vette?
capnron3 (02-20-2019)
The injectors on my 82 were dripping gas while pulsing. I pulled them and sent them off to FIC for rebuild. Relatively inexpensive and quick turn-around. Just make sure you record the stamped part number along with its location on the manifold. The injectors are not identical.
Received 1,469 Likes
Cruise-In II Veteran
FWIW: have you check the fuel vapor canister?
Dr. Detroit
Received 3,892 Likes
Jebby
EDIT: Learn something every day!!!!
https://www.rockauto.com/en/catalog/...+injector,6224
Wow...really? I wonder what would be different about them?
Jebby
Jebby
I had this problem on my 82. Turns out when the previous owner installed a crate engine he did not install the O2 sensor! :O
I bought a new O2 sensor and installed and at the same time converted to dual exhaust and it's never done that again.
