Recommendations for a manifold for a ZZ4 crate?
What's a good manifold for a ZZ4 350 crate motor in stock condition? Currently has a Holley 670. If you've seen my other threads on this car I'm going to take the blower off it until I get pistons, rods and rings lined up.
Thanks!
Thanks!
Cruise-In IX Veteran
If you have the zz4 manifold use that. Otherwise just put an Edelbrock performer on it. The zz4 runs out of steam just after 5000 rpms, so you don't need anything trick.
Received 3,043 Likes
St. Jude Donor '05
The zz4 thats on it now.
The Chevy ZZ4 manifold actually outperforms most of the aftermarket intakes on the SBC including Edelbrock intakes in tests I have read....If I was looking for an non stock intake I would look for the aluminum ZZ4...........over just about any of the other aftermarket ones
To bring you up to speed, the car as I got it came with a blower that the previous owner put on it not a manifold. I have concerns about whether this engine is right for a blower as discussed at length in another thread so I'm contemplating switching to a manifold for the time being and wondering what a good one would be.
https://www.ebay.com/itm/Chevy-GM-Pe...7ZeB:rk:2:pf:0
brassplyer (02-22-2019)
Another thought would be bigger chamber heads. Then leave the blower there. Those 58cc chambers are tiny. And the heads are nothing special port-wise, just small chambered for raised compression on a regular short block.
htown81vette (02-22-2019)
I'm told it should really have forged pistons as a minimum, forged rods preferably. Plus appropriately gapped rings. Someone said they didn't think it needed the gapped rings because it isn't enough blower but I've seen where someone had trashed ring lands with this same blower.
Short Manifolds (Less Than 5.00 Inch Carb Pad Height)
Manifold PN Price PeakTQ Peak HP Avg. TQ Carb Ht. TQ at 3,000
Edelbrock EPS 2701 $139.95 506 461 466.2 4.80 476
Edelbrock Air Gap2601 $225.95 504 458 464.7 4.92 478
Chevrolet ZZ4 10185063 $239.95 500 471 464.5 4.95 467
WeiandStreetWarrior8125 $151.95 501 463 463.5 3.65 470
WeiandStreetWarrior8120 $134.95 502 459 462.8 4.62 471
Summit Stage 1 226012 $131.95 498 459 461.0 4.65 468
Edelbrock Performer2101 $157.95 494 456 459.1 4.60 470
Prof. Prod.
Cyclone 52001 $143.95 487 436 449.3 4.72 471
Edelbrock RPM 7101 $174.95 504 470 468.3 5.25 474
Source is Car Craft Magazine^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Again, numbers do not lie^^^^^^^^. The ZZ4 aluminum manifold is more than a match for the edlebrock performer (beating that one handily) and a match for the Edelbrock performer RPM on a fairly high HP/TQ motor. GM claims the the ZZ4 makes the same HP/TQ as the famed high rise LT-1 manifold BUT is 0.5 inch shorter in height. The RPM makes 4 more peak HP than the ZZ4 but 1 less ftlb of peak TQ, none of which can be felt on 450+ gross HP motor...it is a meaningless difference and probably is no difference on a sub 450+ Gross HP motor. The only reason to go with a performer RPM is that it may be slightly less money than the ZZ4...performance wise there is no meaningful statistical difference......
Prof. Prod.
68post (02-27-2019)
