Solid Motor Mounts ???
Old Feb 26, 2019 | 12:02 AM
OldCarBum's Avatar
OldCarBum
Default Solid Motor Mounts ???
I'm planning to use solid motor mounts on my 73 with the 496 cu in motor I'm building.
I've heard negative things about using rubber mounts with the amount of torque my motor will be putting out and negative things about poly mounts breaking down when subjected to heat.
Are there any negatives in using solid mounts or problems I need to know about?
I plan to install the 73 OEM style rubber body mounts which will absorb most of the vibrations in the chassis with the solid motor mounts.
There are several manufactures of solid motor mounts for C3's and I was wondering what brands are the best?
Old Feb 26, 2019 | 12:09 AM
REELAV8R's Avatar
REELAV8R
I have a solid mount on the left side of the motor and a rubber one on the right. I believe moroso is the brand of the solid.
no complaints from me about vibration being transferred to the cabin, but I do run side pipes so they may be drowning it out.
Old Feb 26, 2019 | 12:14 AM
Vette5311's Avatar
Vette5311
You won't like them if you do any amount of street driving. Race car stuff only. They transfer all the NVH (noise vibration harshness) directly on to the interior. Put the rubber or poly mounts in but build a torque limiting device that only lets the motor lift a very small amount before stopping movement. I use a turnbuckle from the hardware store and replace one hook end with a bolt that goes through the frame and then hook the other end to a bolt in the head, the alt bracket or some other convenient spot that will stop torque over from the left. You don't have to worry about the passenger side at all. Just the lift on the driver side.
Old Feb 26, 2019 | 12:23 AM
Metalhead140's Avatar
Metalhead140
C3 of Year Finalist (track prepared) 2019
I have solid Moroso mounts. With rubber body bushings and a well balanced motor, there is NO noticeable NVH problems as a result, and it has stiffened the front of the frame nicely. Make sure you use a compliant gearbox mount still, particularly with a factory cast bellhousing.
Old Feb 26, 2019 | 05:55 AM
74_stingray's Avatar
74_stingray
C3 of Year Finalist (performance mods) 2019
St. Jude Donor '19
OldCarBum, I run Moroso solid motor mounts in my 74 coupe with a 383 and 4 speed. I didn’t notice very much difference if any from the rubber mounts. The solid motor mounts are used in conjunction with a spreader bar, I believe it really solidifies the front of the car, making the engine an integral piece of the chassis. Having said that, I do view this car as a performance vehicle and don’t have the expectations of a modern street car. I have no regrets about changing mounts. I view this modification as a personal preference, I like it, and they are relatively inexpensive so no worries if you don’t like them. Just my .02
Eddy
Old Feb 26, 2019 | 08:23 AM
bashcraft's Avatar
bashcraft
You can buy rubber mounts that have a movement limiting feature designed into them. This one is made by Lakewood, but I'm not sure if it will fit a Corvette.
Old Feb 26, 2019 | 08:26 AM
HeadsU.P.'s Avatar
HeadsU.P.
Moroso Solids, Grade 8 Bolts, drop of Loctite Blue, never look back.
Maybe a ever so slight tingle in the steering wheel. Hardly worth mentioning. It lets you know you no longer have 180 horse.
On the transmission mount however, I prefer some rubber there, so as not to get the tingle through the shift ****. And the rubber mount should take any vibes out of the driveshaft, U-Joints, etc.
Some of us older children still remember the GM motor mount breakage of decades ago. Not pretty when the whole engine tilted to one side.
Old Feb 26, 2019 | 09:01 AM
Bikespace's Avatar
Bikespace
I have the Moroso solids, and both the Energy Suspension and rubber trans mounts, waiting to go in the car. A local garage quoted me $300- to do all three. I'm tempted to take them up on it, probably with the rubber trans mount.
My current mounts have failed. Nothing holds the engine from rotating except weight and the backup tabs.
Old Feb 26, 2019 | 10:03 AM
bradleyb66's Avatar
bradleyb66
We put the Moroso solid mounts in our 79, after my son broke two of the rubber mounts with an almost stock engine (Don't ask me how he managed that - I'm SURE they were just defective... ). Didn't notice any extra vibrations at all.
Old Feb 26, 2019 | 10:12 AM
74_stingray
St. Jude Donor '19
It's not a very difficult job in my opinion to change the motor mounts. I changed mine on the Kwicklift without much hassle, don't see any problem using jack stands either. I used ARP bolts for mount to block and mount to frame, I did not need to change the transmission mount it was good. The motor mounts were also good, I just opted for solids for reasons stated above.
Eddy
Old Feb 26, 2019 | 10:16 AM
73racevette's Avatar
73racevette
My 73 had solid Moroso mounts with a lower HP 454 when I bought it. Before I tore it apart, I ran it a bit and there was no vibration that I could tell. Going back with a 488 in the 600hp range and I used Moroso solid mounts. Have not run it since the rebuild yet, but based on the initial feel I don't expect much if any vibration. Side benefit is the engine helps to substantially stiffen the front of the frame.
Old Feb 26, 2019 | 11:15 AM
OldCarBum's Avatar
OldCarBum
Thanks guys,
It looks like the Moroso solid mounts will be my choice.
I am planning to run the rubber trans mount supplied with my SST TH-400 to TKO-600 conversion kit bolted to my G-Force cross member.
Van Steel set me up with a spreader bar that is going to be a tight squeeze with the big block, but with running the dual Spal fans from DeWitts, I should have just enough room.
Old Feb 26, 2019 | 12:12 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
The first holeshot I pulled with my fresh 406 broke the drivers mount....I went Moroso solid on the drivers side and zero issues with NVH.
Jebby
Old Feb 26, 2019 | 12:39 PM
OldCarBum's Avatar
OldCarBum
Thanks Jebby,
A couple people commented in this thread that they, like you, installed a solid mount on just the drivers side.
I understand why, but is there some type of significant advantage to only installing the solid motor mount to one side and not to both?
Old Feb 26, 2019 | 12:44 PM
HeadsU.P.'s Avatar
HeadsU.P.
One side gets pushed on, the other side gets pulled on because of the torque rotation. I believe the mounts are sold in pairs. Why not install both?
Old Feb 26, 2019 | 01:18 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Because I am lazy....the passenger rubber mount was new and only acts as a “pivot”.....
A lot of stuff is in the way compared to the drivers side.....I may install it one day....but maybe that is why I have no vibration....it is rubber on one side...who knows!
Jebby
Old Feb 26, 2019 | 01:30 PM
suprspooky's Avatar
suprspooky
I'm thinking of installing the Moroso solid, anybody have the P/N handy? I'm even lazier than Jebby
To Solid Motor Mounts ???
Old Feb 26, 2019 | 01:36 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Now that is tough to do!
63-82 SBC,BBC pt# 62530
Jebby
Old Feb 26, 2019 | 01:39 PM
OldCarBum's Avatar
OldCarBum
Moroso's web site states that a solid transmission mount must be used with solid motor mounts.
Any negative issues with running the solid trans mount?
"Solid Motor Mounts must be used in conjunction with Solid Transmission Mounts to prevent breakage of engine block and transmission case due to torsional stress"
v2racing's Avatar
v2racing
I have solid mounts in my car. I also have the differential mounted solid and I have virtually no noticeable vibration.
Mike
