Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Reload this Page >
Very Odd Situation 3 of 4 Outings in a Row, Please Read
Old 03-07-2019, 08:13 AM
Jstan2014
CF Senior Member
Jstan2014's Avatar
Liked 253 Times in 220 Posts
Originally Posted by Jebbysan View Post
Greetings from New Braunfels......my wife goes to Round Rock for work several times a month....
Replace the small 8" inch piece of rubber hose that goes from the gas tank sender to the fuel line. This can deteriorate and close off internally and because it is on the suction side.....cut off fuel to the pump. It may collapse just enough to only allow a trickle of gas through and when the float bowl is full it runs fine.....but when it can't keep up because of a partially blocked line.....it stalls. Wait 5-10 minutes and it starts right back up.......runs great.....go another couple of miles and kaput.
This is what happened to the car in my Avatar......it drove me nuts for a month til I was under it looking at stuff and took a chance removing that hose as I was out of options.......
After two fuel pumps.....insulating gaskets for the carb, shooting it with a $6000 thermal image scanner I borrowed ( which showed nothing out of the ordinary), a $1 piece of fuel hose fixed it....
Jebby
Thanks Jebby! The PO did this, but maybe not correctly. But, it is new hose.
Jstan2014 is offline
Old 03-07-2019, 08:14 AM
stingr69
CF Senior Member
stingr69's Avatar
Liked 126 Times in 122 Posts
My advice - Ignition coil and condenser need to be replaced with known good, non-aftermarket parts. Exact thing happened to my '80 after I did an ignition "upgrade". Going back to the old stock parts solved the problem.
stingr69 is online now
The following users liked this post: stingr69
Jstan2014 (03-07-2019)
Old 03-07-2019, 08:35 AM
Jebbysan
CF Senior Member
Jebbysan's Avatar
Liked 378 Times in 333 Posts
Originally Posted by Jstan2014 View Post
Thanks Jenny. The PO did this, but maybe not correctly. But, it is new hose.
Great.....now when it quits next time, hop out and look into the primary side of the carb. Whack the throttle and look for Accel pump squirt. If there is none then fuel is the issue. If not...you just narrowed down by half!
Jebby
Jebbysan is offline
The following users liked this post: Jebbysan
Old 03-07-2019, 09:28 AM
Jstan2014
CF Senior Member
Jstan2014's Avatar
Jebby
Thanks Jebby! ( Sorry for the auto correct typo above. I fixed that in the original post) I just drove 8 miles with no problem after having stalled out yesterday. Crazy that this never happens unless the car has sat for several days. Thanks to ALL for the good advice. This will be solved.
Old 03-07-2019, 10:49 AM
Big2Bird
CF Senior Member
Big2Bird's Avatar
Liked 447 Times in 418 Posts
Intermittent failures can drive you bonkers.
Its always something stupid easy and cheap.
Youll find it. Sometimes its blind luck. Sometimes it just takes awhile to figure it out.
A bad ignition switch that is failing for example.
Big2Bird is offline
The following users liked this post: Big2Bird
Old 03-07-2019, 03:09 PM
ignatz
CF Senior Member
ignatz's Avatar
Liked 205 Times in 170 Posts
I had a similar problem once that I decided had to be fuel related. Flushed all the lines, changed all the filters, yet the car would randomly stall as if it had run out of fuel. Pull over to the side, wait a while and it would start right up. Naturally the one place I didn't think to look was where the problem was. Turns out the line between the pump and the AC filter had some large piece of debris in there. I don't know how it got past the pump. I guess what was going on was the debris would randomly tumble around until it blocked the line. Shut the car off and it would sink back down and the car would start and run just fine again.
The somewhat consistent behavior of your problem maybe doesn't click with my situation but I thought I would share.
ignatz is offline
The following users liked this post: ignatz
Old 03-08-2019, 02:43 PM
Big2Bird
CF Senior Member
Big2Bird's Avatar
That kind of thing drives you bonkers.
Big2Bird is offline
Jstan2014 (03-10-2019)
Old 03-08-2019, 03:12 PM
theandies
CF Senior Member
theandies's Avatar
Location: "The tree of liberty must be refreshed from time to time with the blood of patriots and tyrants."
Liked 291 Times in 245 Posts
Sounds like you are draining your fuel bowl shortly after starting and driving a bit. I'd change out all the rubber hoses, replace the fuel filter in the carb (q-jet???), check your fuel pressure coming out of the pump. Should be at least 4 to 6psi.
I would think if your coil etc. was getting hot you'd be able to drive it, coil overheat and you stall, wait a few minutes and the coil cools, start it back up and the coil should overheat again but your description (if I'm reading it right) is after this happens shortly after starting your trip then never happens again during your trip?
theandies is offline
The following users liked this post: theandies
Jstan2014 (03-08-2019)
Old 03-08-2019, 04:05 PM
Jstan2014
CF Senior Member
Jstan2014's Avatar
Yes, you are correct. The car starts with no problems after it has died. Now, Iíve had the car home the past two nights. Iíve driven the car two times, yesterday and today, with no problems at all. Iíve driven a 10 mile round trip both days with a WOT run up to 60 mph. She runs strong. I canít help but question if the storage unit and the cold nights weíve had played a role in all three ďepisodesĒ of dying the way itís happened. Itís as though Iím out of gas but Iím not. I asked this earlier, but Iíll ask again. After several nights, could there be condensation in the fuel lines that makes its way to the carb, kills the engine/burns thru the system, and then Iím able to restart and go? It should be noted that this never happened last summer when we first got the car. Itís only been a winter issue. Maybe the C3 doesnít like sharing ďgarage timeĒ with the C6? Crazy, I know. Itís getting warm here and this may not happen again until next winter. I had my video camera ready to record today so that If/when this happens again I can show everyone what itís doing. I know it sounds crazy.
Ps: all fuel lines and hoses were replaced by the PO. The fuel tank is new also. I canít be too certain if the fuel pump was replaced, but it seems to work fine even though I have no way to check the fuel pressure. Thanks all!
Old 03-08-2019, 04:39 PM
theandies
CF Senior Member
theandies's Avatar
Check the "S" lines at the fuel pump. Some "previous owners that say something has been replaced" might have had regular fuel lines installed at this location. These are special molded hoses that will not kink when flexing like straight auto part store cut it off the spool type fuel hose. (Thanks for the picture Wilcox!!)
Yes, you might have water in your fuel. Before you drive again take your filler cap off and see if it's wet. Water will sink to the bottom of the tank so its possible after sitting for a few days or a week you'd have water at the bottom of the tank. When I was flying/mechanic on small aircraft part of the pre-flight was to drain the sumps of the fuel tanks and check for water. In Avgas you can see it plain as day because Avgas is dyed light blue for ID purposes.
Old 03-08-2019, 05:22 PM
Jstan2014
CF Senior Member
Jstan2014's Avatar
theandies:..... There’s no “S” hose under my hood. It looks like fresh off the spool fuel hose to me. (I’m not surprised though, I’ve found quite a few corners that were cut during the “rebuild”.) Also, I’ll check again for water the next time I leave it at the storage. I’ve never actually seen any water or droplets of water in the tank or under the cap, but I wasn’t sure if I’d be able to see it or not. Thanks!
Old 03-08-2019, 07:10 PM
theandies
CF Senior Member
theandies's Avatar
I'd replace the bubba fuel line with the correct one even if it's not the cause of your problem. That line prevents the fuel line from kinking when your engine torques over.
You won't see the water in the tank unless you have a sump and are able to drain it like on small Cessna's as I explained. If water is condensing in your tank then I would think you'd see it on the bottom side of your filler cap. Does your storage room have electricity? I keep my Vette in a detached 1 car garage and during the winter I have a small heater running to keep the temp in the garage between 40 and 50 degree depending on how cold it is outside. Might not work too good in a storage locker as they are usually open to the one's next to yours in the roof area. Hate to try and heat all the storage lockers. LoL
Old 03-08-2019, 07:26 PM
  #33
Jstan2014
CF Senior Member
Jstan2014's Avatar
Roger that. Not only is it not the “S” hose, it has virtually no slack in it. I suspect that could be problematic in its own right No, the off-site storage unit has no power. I think I’ll keep the C3 here at home for now. The attached house garage obviously has power to it, and it’s also indirectly “semi-climate controlled” thru a storage space that has passive air flow (leaks) from under the house stairs into the garage. The garage is always appx 10-15* cooler in the summer and 10-15* warmer in the winter than the ambient outside air temperature!
Old 03-09-2019, 02:45 PM
  #34
Street Rat
CF Senior Member
Support Corvetteforum!
Street Rat's Avatar
Liked 303 Times in 282 Posts
Joe
Text me if you want to bring the car by my place tomorrow. I'll take a look at it if you want.
Craig
Street Rat is offline
The following users liked this post: Street Rat
Jstan2014 (03-09-2019)
Old 03-09-2019, 02:52 PM
  #35
theandies
CF Senior Member
theandies's Avatar
Jstan2014 - Just realized you are in Round Rock. We lived there in the Cat Hollow neighborhood for about 10 years. We liked it but growing up on the east coast we were glad we got the opportunity to move back east. Sorry for the off topic.
Old 03-09-2019, 03:05 PM
  #36
Jstan2014
CF Senior Member
Jstan2014's Avatar
Originally Posted by Street Rat View Post
Joe
Craig
Craig,
That would be a HUGE help! Iíll text you shortly. We just got home. It was good to see you today. Your Ď81 looked great!
Thanks,
Joe
Old 03-09-2019, 03:15 PM
  #37
Jstan2014
CF Senior Member
Jstan2014's Avatar
No need to apologize my friend. Itís a crazy small world! We are on year 12 in Round Rock ourselves. We still love it here but the summers seem to be getter hotter and hotter.
Old 03-09-2019, 03:29 PM
  #38
Jstan2014
CF Senior Member
Jstan2014's Avatar
Day three UPDATE: I went out this morning for a test run. The car has been home now for three days and driven everyday. I’ve had two days with no problems. Today she stumbled when pulling away from the house, and ran about 3 miles okay. I went thru the ATM line, and began driving back home. She started cutting out, but not surging as strong as before. About 1/2 mile from the house she died. She simply cut off as though the ignition was turned off. I rolled to a stop in the right lane, put her in park, turned the key, and she fired right back up. I drove her home and parked her.
I checked for signs of water/ condensation before I began my drive. There was none. My theory is shot. It is now happening while parked in the home garage so the storage unit conditions are not a factor. It also has now happened after two days of no problems. The mystery continues. Maybe StreetRat and I can figure this out!
The following users liked this post: Jstan2014
theandies (03-09-2019)
Old 03-10-2019, 12:53 PM
  #39
REELAV8R
CF Senior Member
REELAV8R's Avatar
Liked 284 Times in 262 Posts
I think I would look for condensation under the distributor cap.
after it warms a bit the moisture begins to evaporate and may be causing some electrical issues for you under the cap.
WD 40 was made for removing such types of moisture.
REELAV8R is offline
The following users liked this post: REELAV8R
Old 03-10-2019, 02:53 PM
  #40
itsforfun
CF Senior Member
Liked 12 Times in 12 Posts
It sure sounds like a fuel issue, but you have done almost everything to resolve the issue. When was the carburetor cleaned or inspected? Sounds like a float malfunction or jet getting intermittently clogged. And when you press the accelerator on restart, the accelerator pump stirs up the gas in the bowl, shakes the float, and everything goes back to normal.
itsforfun is offline
The following users liked this post: itsforfun
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
