Mystery hose. Anyone know what this is?
Working on a vacuum leak on my '70 and i accidentally snapped a T. The thick hose coming from the left is coming from the vacuum tank. There is a T and a thick hose coming out of the right hand side that attaches to the wiper actuator relay. There other side of the T is a much smaller barb that was connected to a small hose that runs through the firewall. I tried to trace it but couldn't find where it's going. Since it's broken, while trouble shooting the vacuum issues i hooked the thicker yellow striped hose directly to the relay without the T and everything seems to be fine with the smaller hose disconnected. Any idea what that smaller hose is? Thanks
pwsusi (03-09-2019)
I think that is the vacuum source hose for your heater - defrost - vent control.
pwsusi (03-09-2019)
Thanks guys. That must be it! I'll have to check local parts store to see if I can get a new one..otherwise maybe jbweld
EBay is your friend... there are probably better options if you look but this should work.
https://rover.ebay.com/rover/0/0/0?m...2F391761055320
pwsusi (03-09-2019)
pwsusi (03-09-2019)
You might be able to find what you need in the way of the T at Autozone or NAPA since they sell that sort of thing. I have no idea on a 70 where stuff goes, sorry.
pwsusi (03-09-2019)
pwsusi (03-09-2019)
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
EBay is NOT your friend. They suck... lol
Here is a vacuum hose diagram for your car.
pwsusi (03-09-2019)
Head to your local autozone and get an assortment.
https://www.autozone.com/fittings-an...ent/365546_0_0
Received 3,220 Likes
If you want higher quality replacement- just a few bucks more-
Go to your local hardware store and get some made out of brass- mine had all sorts of sizes a couple -three bucks apiece.
Former Vendor
But carriljc is right, you can buy the same tee in the Dorman kit at most local parts houses. While it's white, you can paint it back to make it appear original. If the OP wants an original one he should email me direct @ Service@Willcoxcorvette.com, I've probably got an original one on a hose kit here... however, it would also be a 40 plus year old T and probably still be brittle like the one he broke.
Willcox
Hello.
I'm reading your post and wondering if you solved your issue with the vacuum hose? I'm installing the Climate Control Vacuum Hose Kit (11492K Paragon) that I purchased form Corvette Central. The directions aren't very clear.
I'm replacing the long black hose that goes from the inside controller through the firewall.
Any help would be appreciated.
John
John
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,326 Likes
This thread is 5 years old and the OP has not logged on the site in 3 years. Please start a new thread with your question.
John Parodi (03-16-2024)
